Brass Ferrules
Eric Knutsen
>I am looking to make some tools and I would like to cap the top of tha handle with a brass ferrule as you would see on store bought tools. Can anyone tell me where to find them?
Brass Ferrules
Eric Knutsen
Re: Brass Ferrules
Tony - Memphis
>I have bought them from Lee Valley. A little thin, but they look nice.
Tony
Re: Brass Ferrules
Jennifer@Indy.USA
>Copper pipe from Lowes, HD works great, looks good and is much cheaper.
Jen
Re: Brass Ferrules *LINK*
E.T.
>Brass ferrules are available from the mail order places. See the link below. I have bought short length of brass pipe called "nipples" from plumbing supply stores, including Home Depot. These are threaded on both ends but even when the threaded portion is discarded there is enough pipe left in a 6" nipple to band 4 or 5 tool handles. ET
http://www.woodturnerscatalog.com/cgi-bin/shopper?preadd=action&key=050-7026
Re: Brass Ferrules
Halsey
>Brass compression nuts work well. Just thread them on and turn them round. They come in many sizes. Halsey
Re: Brass Ferrules
Thad Parker
>I've used large brass nuts found in a nut bucket in the corner of the shop...threaded them on, and turned 'em round...just what I had laying around.
~ Thad
Re: Brass Ferrules
eliot d
>Eric,
I just use copper tubing from the hardware store. But here's something I learned from Michael Hausolic(sp?)Get some round brass stock ( or mild steel) and drill a hole down the center of it the size of the tool shafts you will be using. Also turn down a part of it to something like 1/2 inch diameter. Drill and tap two small holes, say 1/4 inch,into the wider portion for two set screws. Then make your handle as usual , but , instead of gluing in the tool shaft, glue in the smaller diameter section of this metal adapter. Then you can insert your tool shaft and tighten the set screws to use your tool -- AND you can take your tool out again! So you can interchange tools so long as they have the same shaft diameter. I did something like this with hardware store 3/4 in, dia. mild steel; the whole think cost me $1.20 for two $0.60 1/4 x 20 set screws, because I had some mild steel rod lying around the shop.
Re: Brass Ferrules
John Kyler
>Alan Batty has always said the copper will stretch when the wood expands and contracts, where brass wont.
Re: Brass Ferrules
>John That's interesting and probably somewhat true but I suspect the wood will compress before the coppper has much time to do anything. Copper also moves more than brass from temperature exchanges. I've used copper, aluminum, brass, dental floss, and wire for ferrules. I like brass. If you look at all the tools on the market brass is the preferred ferrule material. I suspect it's looks and tradition as much as everything else.
My favorite materials are brass compression nuts and Pipe nipples. The pipe nipples are are thick. I cut pieces off and then put them on a wooden jam chuck and turn one side square. This goes against the wood when making the handle. The other side will be turned true after it's glue on. I score the inside with a dremel to aid in the mechanical bonding of using epoxy.
The compression nuts work great and never come loose. Brass and copper will eventually come loose do to wood shrinkage, but not the brass compression nuts. I turn away the hex and this sometimes leaves the brass a little thin but I've never had any problems. I probably have at least 10 tools made this way.
Re: Brass Ferrules
Eric Knutsen
>Good idea.... Thanks.
