New Direction
New Direction
New Direction
Jim Shaver - Oakville, Ontario
>Hi,
I have been making a few new pens. These are solid ended pens based on some Baron kit hardware, with a recessed clip.
Photo Sharing and Video Hosting at Photobucket
I have been using less and less of the kit hardware and experimenting with design, these are taking my pen making in a new direction.
The pens are made with Alternative Ivory (Craft Supply) and black onyx cabochons (Fire Mountain Gems).
The finish is wet sanding with micromesh and Novus plastic polish.
Comments, critiques are all welcomed,
Take care,
Jim
Re: New Direction
Re: New Direction
keith zimmerman, Normal, IL
>Jim, I really like your new direction. These pens are spectacular! The chrome (assumed) finish combined with the black and white are a stunning combination. The recessed clip tops it all off.
I can't wait to see more of these pens as you continue to work in this direction.
keith
Re: New Direction
Re: New Direction
dwr
>Jim,
These are very elegant... nicely done!
I have seen other recessed clip methods where the top is sliced off, barrel notched, clip added then the top glued back on... leaving an obvious glue line.
Your pens show absolutely no indication of how you recessed the clips! Care to share just how you accomplished such a flawless execution of a recessed clip?
Dave
Re: New Direction
Re: New Direction
Jennifer@Indy.USA
>Jim these look awesome. I love how clean and unpretentious they are. Simply beautiful.
Bravo!
Jen
Re: New Direction
Re: New Direction *LINK*
>Thanks Dave,
Well The clip has been on my bench for awhile now, a few failures and a few ok ones, these two represent my best attempts to date.
They are indeed cut into a solid end, I followed an artcile by Bill Jackman, http://www.penturners.org/content/recessedpf.pdf
While I did not follow it to the letter, it did give me a start..
Take care,
Jim
Bill Jackman's Article
Re: New Direction
Thanks Keith and Jennifer
>Thanks Keith and Jennifer,
Keith the HW is actually black titanium, hard to tell from the images actually.
I like the Keep It Simple design right now, I think that there is a simple flow in these pens that will make them comfortable to use and probably my keepers.
Take care,
Jim
Re: New Direction
Re: New Direction
Scott Greaves in Blackfoot Idaho
>Hi Jim!
I think you have a winner here! Have you looked into Rich's methods of turning the section out of your own material? I bet they'd look good with the section turned out of black acrylic!
If you produced these in a fountain pen, I bet you could do do a limited edition run of a hundred pens, start your own pen company, and sell these for about $900 a piece!
Your job recessing the clip looks real neat! Dang, the whole thing looks real neat! Very impressive!
Scott.
Re: New Direction
Re: New Direction
>Hi Scott,
Thanks for your kind and thoughful support, your advice and guidance to me over the years has always been an inspiration in helping my pen making improve.
I am not sure I have seen Rich's method, could you share a link?
I sent you an email, when you have time ..
Thanks again, I have a hundred pens to make, $900, hmmm, I like that deal, eh!
Take care,
Jim
Re: New Direction
Keith Tompkins
Re: New Direction
keith tompkins
>Jim, I've never turned a pen. but if I do, I'll use these as my standard...beautifully done.
Re: New Direction
Re: New Direction
>Thanks Keith,
I can imagine with your creative process what you might come up with...it's a slippery slope ....wear grippy shoes..
Take care,
Jim
Re: New Direction
Re: New Direction
Russ Fairfield
>Thanks for showning these pens, Jim. The white and black makes an elegant combination, and easilly adds another $100 to the price of the pen.
Anyone who is at the AAW Symposium in Portland, come and see my presentation on how these can be done. If you can't be there, I will have a video available after the Symposium, and also for sale at the Symposium. The video shows several ways to do this. Recessing the clip really isn't that difficult to do, and there are many possable combinations of clips and kits. We can even use the clip that came with the kit.
On the value of the pen, you will need to do a couple things before it will be a $900 pen. You will have to get rid of the kit nib, and get one of the 14k or 18k solid gold nibs that are being imported. There is no way that anyone is going to pay $900 for a pen with the stiff plated steel $4 nib that came with the kit. In fact, there is no way anyone will pay over %200 for a pen with the kit nib, regardless of how nice it is, unless you find a sucker.
Another suggestion is to get rid of the plated grip area from the kit. You can either tear that one apart, or use the same nib that is available for the Ameroclassic, and similar pens. It screws right into the Baron fittings, and being plastic is easilly turned down and covered with a piece of the ivory. Add the gold nib when you put it back together.
Even if you don't cover it up, the black plastic of the Ameroclassic nib is a better choice for a writing pen. Besides being available in a wide variety of widths from fine to a braod calligraphy tip, it will wear better because it stays black, and all plating on the metal grip will wear off over time. You might also consider that the black will add to the appearance of the pen.
Just a few things to condsider.
Re: New Direction
Re: New Direction
>Thanks Russ,
How did you know I was thinking about trying to find a new way to deal with the nib, I appreciate the feedback.
I do have one of Anthony's 14k nibs, so it is in the works, turning my own holder has been on my mind....
Again, Thank You,
take care,
Jim
