Gluing Velvet into turned box
Greg Earley
>I made a turned ring box out of cocobolo and need to glue a piece of black velvet into the bottom. What's recomended for an adhesive.
I'll post pictures tomorrow.
Thanks
Greg Earley
Re: Gluing Velvet into turned box
I used a 3M spray adhesive ...
Ed Moore
>when I put the fabric in the bottom of the collection plates that I made for our church. They have been in use for a year and I am not aware of any problems that have occurred with the fabric. And I still enjoy seeing the plates passed each Sunday. It's a paternal thing. [grin]
Ed
eaglesc
>I would use the "suedtex" product at Wood craft.
It comes with a "contactact" type cement that is colored to match the "cuedetex.
mask off the areas you don't want the suedtex to adhere to.
Follow the intructctions.
"Poof" the suedtex into the box, after the reccomended waiting time, dump out the excess.
The nice thing anout the suedetex is that it remains soft.
Ditto
Ron in Drums PA
Suede tex like Eagle says!
Wilford Bickel
>That is all I use now to line boxes - the wife is much better at painting on the glue and is to help me do one tonight. Works great and looks much better than wrinkled cloth!
robo hippy
>Our club had a turner in to demo box turning a while back, and he commented that as soon as he started putting the felt in the bottoms, they sold like crazy. Well, I got all the stuff from Woodcraft, and sure enough, the first person in after I started flocking the bottoms, wanted to know if I had any that weren't flocked.
robo hippy
Mike Stafford
Seems a shame....
Mike Stafford
>to cover up all that pretty wood with anything. I think the inside of the box should be sanded and finished as nice as the outside of the box....
Re: Seems a shame....
Wilford Bickel
>Mike, I agree but when a woman wants one for her rings and jewelry she likes and wants the padding of the flocking. DAMHIKT!!
C.W.Stivison
>Nothing more fun to around than a happy woman.
CW
eaglesc
>Though not a turned box here is the WC flocking in a pen presentation /storage box I made a while back.
Not only are the drawers flocked but I also flocked a foam insert made out of laminated "mouse pad foam" to hold the pens.
Russ Fairfield
>I have always preferred to make a separate liner that fits into the bottom of the box, rather than gluing anything permanently to the wood. I cut a piece of stiff cardboard to fit inside the box. The velvet is wrapped around the carboard insert and glued to the underside with Elmer's white glue. Then the insert is held in the bottom of the box with a press-fit, or a piece of carpet tape if it is loose.
Doing this gives the velvet a tucked and fitted appearance around the edges, it allows me to use a piece of padding under it to create a softer bottom. It also allows the liner to be removed if someone asks about buying the box without it, or a different color of velvet. I always finish the bottom under the liner just in case someone wants it bare.
Mike Stafford
Mike Stafford
>Seldom do I line a turned box but on the occasions when I have I do something similar to what Russ describes. I cut my stiff cardboard to fit with enough room for the soft velvet or ultrasuede fabric to be tucked around the perimeter. For the soft cushion I use headliner material that you can buy at most of the fabric stores. It has a nice soft foam backer and velour outer covering. I spray adhesive on the liner and stick my fabric to it. Then I tuck the fabric under and glue it to the cardboard. Now it is a press fit into the box. If I have misjudged and it is a little loose I use a piece of double sided tape to secure the padded disk in the bottom.
