Me and My Skew
Me and My Skew
Me and My Skew
Ron in Drums PA
Re: Me and My Skew
Re: Me and My Skew
Allen Neighbors
>Thanks for showing that, Ron. It gives me a bit more knowledge about balancing torque between a smaller finial shaft and the tool.
Re: Me and My Skew
Biggest and smallest skew
>Here's my smallest skew sitting on my largest. The big one is a 2" Diaminic. The smallest is .032" piano wire. Hopefully I'll have time to use it to make a really really small goblet in the very near future.
Re: Me and My Skew
Re: Biggest and smallest skew
>Do you have a nice binocular stereoscope to go with the small skew? Or at least one of those large magnifiers?
Re: Me and My Skew
>JL bought a Stereo microscope this spring. I needed it to sharpen and shape the mini tools as well as turn the goblets.
Re: Me and My Skew
Re: Can we have a pic of it in action??
Re: Me and My Skew
Re: Round skews are easier to use.
Russ Fairfield
>A round skew is much easier to learn and control. There used to be an attachment available that clamped onto the flat skew to make a short round section on the tool rest. It worked quite well for most work. The last time I saw one of them was at Highland Hardware several years ago.
I made a 1" round skew once. It was a wonderful tool, but far too heavy for most purpoese. It is gathering dust in the same corner of the shop as the 2" diameter ring-tool that looks like a Termite on steroids.
Re: Me and My Skew
>Russ I agree but I find anything over 1/2" thick is too thick at the bottom of the bevel to do many of the finer cuts that I do. I like a thinner skew for that. For larger work it would probably be fine. I've never tried anything larger than 1/2" for a round skew.
I think they called that round attachment a stabilax or something like that. You can rotate the skew better but if you come off the bevel on a bead it will still run uphill just like a rectangular skew. I think people thought it would cure all thier problems but they found out the skew still takes practice.
Re: Me and My Skew
Re: Round skews are easier to use...
Allen Neighbors
>unless you shake like I do. I can't control the oval 1" skew I have nearly as well as I can control the flat 1". I don't know if it because I can't seem to keep it on bevel, or what, but I can get better results with the flat one. I also have a 1/2" flat skew that I practice with some.
Re: Me and My Skew
Ron in Drums PA
>I also made myself a 3/8" round skew.
I find the flat 3/8" skew with rounded corners more useful.
