>I burn just before appling the finsh. I clean up the burn with a tooth brush or defuzzing wheel on a dremel, sometimes lightly sand if needed but not enough to take detail away and put on finish, sealer or what ever you are using. I don't wax on raw wood because it tends to fill in the burns and sometimes looks dirty. I mainly use an oil finish, to me the satin look shows the burning nicer and looks more natural. You will get alot of differient takes on the subject and im not an expert thats just how I do mine. It's amazing what you can do to enhance a subject just with a little detail added. Good Luck. DonL
Wiping with DNA works ok. It dissolves the wood resins and doesn't raise the grain. However, most of the time that I burn there are small chunks of stuff that DNA will not remove and consequently a light sanding with your finish grit removes the stuff and leaves a good surface for your finish.
>I don't burn until it's complete. I sand to whatever it is I'm sanding to. Usually no less than 400 sometimes 600. Then I do my burning. I learned the hard way not to burn after applying any finish. You'll get a lot of gooey build up on your burn pens. I decided to practice on some pieces I had laying around the house that were already finished. Ooops. After you're done burning an area, use rubbing alcohol on a tooth brush to rub out the "ghosting" you'll get on the wood. It will rid the burn of any ash and make for cleaner looking burn lines.
