ADVERTISE HERE - FREE TRIAL
Hunter tool
Hunter tool
Hunter tool
>Here are some photos to show how the Hunter tool cuts. I like this angle the best. If you flatten it out so it cuts more like a scraper it will get a catch. cut at a shear angle and it will be your slave.
The top left is the Oneway Ring tool, top right is the Hunter tool, Bottom left is the hook tool and the bottom right is a bowl gouge. Notice how the wood is rotating past the cutting edge at the same angle for each cutting tool. Of the 4 the Hunter tool gives the best finish followed closely by the ring tool. My hook tool is ground a little thicker at the edge and doesn't cut as clean. The bowl gouge cuts the worst in this orientaton.
The Hunter tool chatters the least followed by the hook tool. This is the 4th Ash box I've hollowed with this tool and the edge is still cutting so clean I can start sanding with 220. It's actually so clean I could probably just wax it and not sand but I guess I'm just hung up on sanding the inside.
Everyone who tried this tool today fell in love with it. I don't like the tool for the outside of boxes as well because it's more difficult to get a really smooth curve on the box side. You can do it of course but I think a bowl gouge or spindle gouge is a better tool for this task.
I did turn a spindle with it and got very clean cuts. I just find it more difficult to control the shape of the spindle.
Re: Hunter tool
Re: Hunter tool
>the Hunter tool is very nice for cutting end grain or across the grain. I cleaned up the lip of the box with this tool and it needs no sanding. You can see how polished the cut is on the left side of the cut line and it's producing fine hair like shavings.
Re: Hunter tool
Re: Hunter tool
C.W.Stivison
>Good information John.
Thanks
CW
Re: Hunter tool
Re: Hunter tool
Russ Fairfield
>John,
I hollowed my 83rd goblet withthe Hunter tool a couple days ago, and it is still as received. I havn't rotated it yet, but will before the next one just to see if there is any difference.
Re: Hunter tool
Re: Hunter tool
Brian Hahn in SW Wisconsin
>Good info John.
But, it looks like someone needs to talk to you about the color balance in the pictures. Maybe Jamie could give you a few pointers. ;-)
Re: Hunter tool
Re: Hunter tool
>Russ I'll be interested in your results. Since you've used it for that many goblets I assume you like it?
Re: Hunter tool
Re: Hunter tool
>It was late, I was tired so I just used Auto color balance which I normally never use. I only worry about color on serious work. Should have used a blue background. :)
Re: Hunter tool
Re: Let's see here-contrasting...
Jamie Donaldson
>... complimentary colors on the color balance wheel, with yellow balancing out the blue from the background, and the resulting color cast would be orangish, just less than what we already have here!
Re: Hunter tool
Hey Russ
Ron in Drums PA
>The goblet I have of yours, did you use the Hunter Tool?
Re: Hunter tool
Re: Hey Russ
Russ Fairfield
>Ron, I don't remember the chronology, but I think not. I got the tool from Mike Hunter when I was in Minneapolis in October. Every one since then has been hollowed with it.
I am using the larger Onway handle with it, and the extra weight is really a benefit.
There are now 2 sizes, the 1/2" and the 3/8" diameter. I cut the 3/8" to a shorter length and stuck it the end of the Stewart straight bar.
Another similar tool is the "Eliminator" that is sold by Brad Packard, and maybe others. It is a longer and heavier 3/4" diameter tool that is tapered down to a smaller cutter. It also has two (2) flats milled along its length at 45-degrees.
Of the two, I prefer the hunter for what I am using it for, ie, shallow hollowings that are no deeper than about 4" to 5" and with an open top. The larger diameter of the 1/2" tool gives me a better surface finish on the dry wood. I also prefer the round shank, because I might like to use a different cutting angle, and the milled flats on the "Eliminator" get in my way for doing that.
The longer length of the Eliminator would be the better tool for hollowing deeper forms. For what I am doing, the longer (a lot longer) Eliminator puts the handle too far back on the cutter for my liking. Personally, I prefer the shortest possible tool extension from the handle and being able to grip the handle as close to the cutting area as possible. The Hunter lets me do that, while the Eliminator does not. The length of the Eliminator is what it is because of its larger diameter, and the turned down shank at the end for the handle makes it a long tool. The Hunter is a straight shank that can be slid to wherever I want it in the Oneway handle.
I cannot recommend one as being better than the other because they essentially do the same thing. For myself, the Hunter tool is the more versatile of the two, and it better suits what I am using it for. Others will have differing opinions because they have different needs and expectations from a turning tool.
Try these tools on wet wood, and you will get long shavings like from a gouge.
Bottom Line:
Either tool is a Helluva lot easier to use and to learn to use than a Termite or Hook Tool.
Re: Hunter tool
>Jamie I live too close to Knoxville so Orange rubs off on everything. :)
Re: Hunter tool
Re: John, can you purchase the
Allen Neighbors
>hunter tool un-handled? Just curious... I have several different handles that I can use, and I don't need to purchase another one.
Thanks for all your time and energy towards bettering this craft.
Re: Hunter tool
Re: Hey Russ
Ron in Drums PA
>Thanks Russ, you sent the goblet to me in Feb 07
Re: Hunter tool
>Yes you can get it unhandled. I prefer to make my own handles when I can because I prefer to choose my lengths. I like Russ's idea of the Oneway handle. I may try that.
