Small problem, solution
Mike Nelson
>Top's off! I tried putting the box in the freezer, got a frozen box. Tried whacking it with a rubber hammer, no luck. Finally stuck it on the vacuum chuck and held a soft cloth to the top to heat it up. Must have expanded the top, came off with a small tap with the rubber hammer. I wonder if I took it right from the freezer to the lathe, it might have just lifted off? Thanks All, Mike
