Tool Rest Issue
Tool Rest Issue
Tool Rest Issue
Eric Knutsen
>I have 2 second hand lathes whose tool rests have some nicks in them. What is the best was to mill them down to get back to a smooth surface. Filing, belt sander, grinder??? Thanks!
Re: Tool Rest Issue
Re: Most nicks can be eliminated....
Jamie Donaldson
>.. with a good file, but ruts and canyons might need extra attention!
Re: Tool Rest Issue
>I agree with Jamie. Usually a file will do it. Just draw file the top and then slide a tool across it. It should slide smoothly even if there are some small nicks left. If it doesn't file some more. If it's really bad you might start with a belt sander but you risk changing the shape if you go too far.
Re: Tool Rest Issue
eliot d
>Some turners( not me yet) are using some kind of super strong glue to glue on hardened steel rods across the top of their tool rests( or they braze them on -- welding doesn't work, for some reason .) If you opt to do that, you probably don't have to bother getting the nicks out. Hardened steel won't nick much , I guess.
Re: Tool Rest Issue
Re: Tool Rest Issue
eaglesc
>I would imagine JB WEld would fill large gaps.
Me? I either hit it with a belt sander or don't use that part of the rest.
Re: Tool Rest Issue
Re: Belt sander will work...
Allen Neighbors
>perfectly, on a long toolrest. Just use a 120 grit belt, and turn it on. Lay your toolrest longways on the belt and swing the handle over in an arc. Swap ends with it, and do the same thing again. Then I use my PC SpeedBlock sander with 320 grit, and buff with black emery on a hard wheel. Does it for me.
I am one of those who have used PC7 to glue on a O-1 steel rod to the top edge of two of my toolrests. It still will nick a little, but not like it used to. There's a spot here somewhere on WC where Ron put a small tute on how I did it... I think this is it: http://www.simplyturning.com/wc/how2/allen.html
Hope this helps.
