>Seeing the recent turnings posted by Molly makes me want to investigate using leather dye.
Can someone pass on information about it's use on wood? I Googled "Leather Dye" and found very little available on the web (at least that Google found). I have found sources out there; I plan to pick up some at Tandy Leather next week.
>That's refering to the family member who never has a job, the rest of the rednecks, of which I probably belong, are good rednecks.
Speaking of rednecks, A comedian was on the other night and said that he doesn't worry about yelling at drivers with NASCAR slogans on their car. If they start to chase him he just turns right. bada boom.
Around here if they want to turn right, they turn left, at least as far as the middle lane and then they pull into the driveway on the right.
Here in Tennessee they have a new turn signal indicator. It warns you when you accidentally turn it on so you can quickly get it back off. You don't want people thinking you've retired here from the North.
It's just too much fun being around all those turners. You can tell that it left me in a good mood.
>I use Fiebings Edge Dye with the handy-dandy applicator top. very easy to use with zero mess. On pine and woods prone to blotching I seal with a coat of deft and then use two coats of dye followed with a thin coat of Jasco tung oil. the tung oil evens it out and gives a subtle sheen without beeing glossy. this will give a solid even black. a single coat or two witout the sealer will show a bit of the wood underneath, but is dificult to get it even.
