Have a question? Ask Woody!
Suppose I wanted to stain...
Carol in Illinois
>a maple wand, or pen, or other small turning. I have a request for a green wand. Otherwise, I usually like to let the wood speak for itself... then again, I should master this technique, I think. How fine should I sand before I apply the stain?
I was thinking about using Minwax water-based stain. I assume, since it's not NGR, that I'll need to sand a bit after?
Thanks.
Re: Suppose I wanted to stain...
Steve Kubien
All I can tell you...
Steve Kubien
>...is to apply the stain and then wipe it off almost immediately (within one minute). I've done some flat-work (can I say that here?) using the Minwax water-based and if you leave it sitting, like you would with an oil-based stain, it will blotch VERY BADLY. You would be resorting to an 80grit gouge to get it 'level' again.
As for prep work, I doubt you need to go any finer than 180-240 grit. Anything beyond that and you may burnish the surface making it tough to stain. Yes, you will need to sand after to knock down any raised grain. Think 320-400 grit and a light touch.
Having said all of that, I haven't stained any turnings. All of my experience is with flat work. If the rules for turnings are different, I hope someone will speak up and let us both know.
Cheers,
Steve Kubien
Ajax, Ontario
Stuart Johnson
>I mixed up some regular powdered Rite dye to color some plain Maple pens (after turning). The blanks took the dye just fine. It is water based so I did need knock down the raised grain before finishing. To be honest I don't remember which finish I used but it was probably one that Russ has posted.
Ron in Drums PA
>Rite dye is a good idea, one that I should try.
I use aniline dyes from Homestead Finishing. They are pricey but a 1/4 tsp in 4oz of water is strong enough that you may only need one coat.
I sand to 240, then raise the grain with clean water. Let dry, sand with 320 then apply the dye. Let dry again and sand with 400. I apply a thinned wipe on lacquer as a sealer. Later, I'll spray with Master's Spray Lacquer.
Anyway, that's how I do it. Hope this helps
If you are only
Terry Quiram, Roanoke Illinois
>doing one then food coloring or a magic marker will work.
Carol in Illinois
>Thanks for the responses. I hadn't thought of Rit Dyes. Good reminder. I'm concerned about using magic marker. I figure I'd get overlap marks or that the marker would come off when I topcoated with shellac or related products. I seem to remember removing magic marker from things with denatured alcohol.
I'm askeered of laquer finishes - the warnings on the labels are all pretty severe. I don't need any (more) neurological damage.
>Carol I like Analine dyes. They go on pretty evenly. A very small amount goes a very long way. I buy red, blue, yellow, black and brown and can mix any color. I did buy some green because I needed a lot of it for a project.
I've only used Rit dye once and I seem to remember it did OK. I wouldn't use stain on turnings if I could help it. It's too easy to get blotching.
>I would suggest sanding finer than you think. The sanding on spendal turning is all across the grain. On flat work 220 is fine but on turnings you may need to go to 320 or 400. Otherwise you get fine grooves around the work that the dye will emphasise.
Re: Be sure to do a .....
Jamie Donaldson
>... final sanding WITH the grain to eliminate the sanding rings.
Barry Turner
>I'd sand to at least 320-grit, then raise the grain with warm water on a small sponge. Let it dry, then sand again to 320 or 400. Then apply the stain. There will be little sanding required after staining if you raise the grain first.
I always do.
Carol in Illinois
>Took me a couple of turnings to remember to do that. I always sand with the grain after ROS or other sanding on flat work. Once I remembered to do that (again, thanks to commentary on the board), I thought "Duh!!!" Sure makes a difference!
Carol in Illinois
>I have some analine dyes, but I'll admit I'm having trouble with them. I don't think I know how much dye I should use per bit of whatever I'm dissolving it in. So far, not much in the way of success.
Does anyone use dye mixed in oil? (Just curious.)
What I like best is shellac... in different shades.
food coloring thinned with water works nicely
robert davis
