Tool Gloat
Tool Gloat
Tool Gloat
C.W.Stivison
>My Neighbor gave me an old lathe made by J.C.Bount and I got it home today. It has a 60" bed and a 5 hp motor.It is going to be a chalenge to get working but I'm sure all my freinds at WC will be willing to give me all the advice I need.
CW
Re: Tool Gloat
Re: Tool Gloat
Doug Thompson near Cleveland
>Looks good Curt. Did you see if the motor runs, check the bearings and clean it up. I found a great product to remove anything on a old machine it's called Grease Lighting (white spray bottle with yellow print)you can find it in the dollar store.
keep us informed
Re: Tool Gloat
Re: Tool Gloat
C.W.Stivison
>The moter turns freely but it takes 3 phase power so I need to get a converter.
CW
Re: Tool Gloat
Re: Tool Gloat
Thad Parker
>My FIL has a similar situation....good old hunk of iron lathe w/ 3 phase power...he's got it connected to 220v single phase...he lets me turn on it when I come to visit by reversing a chord (about 4-5')around the outboard side hand pulley, turning on the lathe, then pulling the chord back out to get it going...works just fine.
Neither myself nor he are electricians, so this is probably not good for the motor...but this would at least let you run it a time or two to see if the bearings squeal & trouble shoot other things while cleaning it up prior to getting a converter.
Or maybe someone who actually knows more about electricity will chime in and say how bad of an idea this is...or maybe it's fine to do indefinitely...guess we'll see.
~ thad
Re: Tool Gloat
Re: Tool Gloat
Brian Simmons, Heflin, AL
>If the bearings are good, you could mount a pulley on the outboard side and connect a smaller motor to it thus turning the existing motor into your headstock. This would greatly reduce the cost of the VFD. For under $200 you could buy a 1.5 HP VFD and 3ph motor off of ebay. Pulleys could be purchased from surpluscenter.com
Re: Tool Gloat
Re: Tool Gloat
>There are some excellent articles on the web about creating 3 phase from single phase by using another single phase motor to add the 3rd phase. It's quite simple to do and inexpensive.
Brian's idea is very workable.
The big phase converters are expensive but easy to hook up. The Variable Frequency drives work wonderful but you need to be comfortable with wiring fancier devices to hook them up and unless your a motor technician it's hard to know which one to buy for your motor. I've hooked up 3, 2 worked perfectly the other had to go to the local motor repair shop to get it working. It turned out he needed a different VFD even though the motor and current specs matched. I wasn't there so I don't know what the problem was.
