Re: Urgent Harddrive question the "Pro's"
Fog Tanner
>Sounds like a bearing. If it is it could die in five minutes, days, months, or longer. I always assume worst case and do it now before it totally sizes up. My background is working with large IBM mainframe systems where backup and recovery are near and dear to the heart. Some of the same methodology I apply to my PCs (have a several).
The best backup we(several mainframe friends of mine) have found are docking bays for the tower or desk tops. These fit in the same size bay that the CD/DVD reside. They come with a caddy for mouting a normal size disk drive. These may be cabled on the secondary controller, depending on the brand you would have to adjust the jumper settings. Maxtor is the easiest and Western Digital is a little fussier. I don't use other brand as they have less than steller records, best results with them is to drill a hole through the case and platters then run a drywall screw through it to make sure you don't accidentally use it. I have a "other" brand that was given to me - it will never turn again -totally froze up without warning.
I have used a number of different pieces of software to copy the partitions over the years. For the majority of that time I have used Partition Magic and Drive Image. But their usablity and support has gone down over the years. I am still using V6 for my Windowz 98 systems and have a copy of Win2000 version for use on my Win2k system. I have had some issues with both and had to use one of my Linux systems to correct soem of the problems they created. If you don't run a multiboot manager, you probably would not have the same issues. I have used Ghost and it appears to work OK, but also has problems at times.
I continue to look for another piece of software for copying partitions. You really need to copy the partition asis, if you are running the NTFS or later file system. NT (win2k, xp) maintains its own directory and doesn't really care to have the partiton "shrunk" outsize of itself. Trust me on that :-) You can find a starting place for software on www.tucows.com. They have both windowz and Linux groups.
If you are a software jock, there are a number of opensource pieces of code for partition manipulation. But most are Linux based and require a little more knowledge than the basic windowz environment. But, they are real handy for fixing the logic failures of the various windowz utilities. The last thing I every use is the utilities that come with the harddrive. I have had to fix the problmes they create more than I have been able to find them usefull.
Since you already have a good plan of keeping data on a seperate drive. I would suggest that you have a partition on that drive for your apps and leave the OS(s) to your priamry drive. Most of the viruii that you get will hit the C drive. If you set the bootsector as protetcted on the secondary drive, it is pretty hard for them to trash the partition table on that volume. Then when you buy a drive, buy two one as a replacement for the failing drive and a second for backing up your two drives. I currently have fourteen drives for backing up five systems, plus a couple of spare for installing some new version of Linux or a test Wyndowz.
