Fungus prevention
Fungus prevention
Fungus prevention
Dave Winters
>What can be used to cut down on fungus growth on freshly sawn bowl blanks? Often I'll put 'em in a plastic bag before green turning, but on some species after just a few days there will be fungus growing rampant. I'm thinking there must me something I can spray on (Lysol?)that will help prevent this.
Thanks!
Re: Fungus prevention
Don in Central Illinois
>One of the prettiest hollow forms I have was caused by fungus growth. I had it in a plastic bag and when I took it out and finished it, it has this really neat veining, caused by the fungus. My wife latched onto it immediatly. Other than respitory problems, you might want to try a couple of bowls using the fungi growth.
And DO use a respirator!!!
Jack Savona
Russ Babbitt Jr.
>Open the bag every so often to dry some of the moisture. Use paper bags instead of plastic to "slow" the drying. Using plastic bags can be a way on encouraging spalt (fungus) for some great patterns in the wood. As mentioned it is not heatly to breate the dust from spalted pieces so use a mask of some kind.
Gary Evans Tallassee, TN
>Hi Dave,
There are also some vegetable washes that are anit-fungal. Dousing the blank with one of those will help to slow the growth of fungi.
Gary
Brian Hahn in SW Wisconsin
>A coat of Anchorseal will prevent it. A coat of shellac will prevent it. In general, almost any method of sealing the wood will prevent it.
Chlorine bleach might not prevent it but it will at least delay it for a while.
Bill Turpin in WNC mountains
>Mist the blank or rough turned bowl with the cheapest Real Lemon juice you can buy. It does not leave any unpleasant odor or residue.
Bill
must disagree (long)...Re: Fungus prevention
GaryG in MD
>Sorry Brian, but my experience is different.
I've been fighting a rampant fungus attack in some nice pieces of curly silver maple I got recently. I had more than I could deal with promptly and made the mistake of putting it in plastic bags for a few days before cutting it to size. Never again! Paper only. (Sounds kinda like a grocery store...) As a result, I got the dreaded growing black spots. I could literally watch them getting bigger every day.
With plastic, there's a good chance you'll get a black fungus growing in only a few days. In my experience, putting freshly cut blanks into a plastic bag is a very bad idea. I'll never do it again. Let it sit in open air and risk the cracks or wrap in paper -- it's a good use for all those piles of newspapers laying around. After cutting to size, let them dry for a day or so before sealing with Anchorseal. If the spores are present, even that won't be enough to stop the attack because they're on the wood under the wax where the moisture is. It's best to rough right away and boil or DNA or microwave. But, of course, we always get more wood than we can rough -- hence the problem.
The problem is moisture -- the fungus grows in moist wood. Once started, it is hard to stop short of boiling or DNA, neither of which are very appropriate for unroughed hunks. The purpose of Anchorseal or shellac is to slow drying so the blank doesn't crack. Slowing the drying just gives more time for the fungus to grow. Indeed, I actually have the fungus growing in the layer of Anchorseal which is, after all, put on as a water emulsion.
I have been roughing these things as quickly as I can so I can deal with the fungus. I'm not talking about anything as nice as spalt here -- I'm talking about a nasty gray cast (from black pores) that takes over and makes the turning generally unattractive. Once you have a roughout, boiling or DNA will kill the fungus, but you still have ugly wood. So first, after roughing, you need to remove the offending color with lemon juice or bleach -- then DNA it or microwave it because even after the piece has been in one of these liquids, the fungus will start to grow again in two days. DAMHIK! You have to dry it quickly.
I have a 12 incher in DNA right now -- it'll come out in the morning. The DNA causes a surface color change (generally a darkening in lighter woods) too, but that's supposed to go away when you re-turn the blank and get beyond that altered surface layer. I'm hoping so, anyway. I'll let you know in a few weeks. I'll be very disappointed if I lose this fiddleback.
...Gary
Dave Winters
>Thanks, all. After doing a Google search, I read that Hydrogen Peroxide is a good antifungal as well. And it's cheap. So I'll try it and post results.
GaryG in MD
>Dave,
H2O2 will work, but it is very much more expensive than bleach or lemon juice. You'll need a fair amount because it has to soak all the way deep into the wood -- because that's what the fungus does -- the fungus goes in the pores and can penetrate a blank completely in a few days. A quick splash of fungus killer on the outside of the blank will not work -- it has to soak for many hours, or even days. Further, peroxide tends to lose its potency very quickly, where the others won't.
...Gary
I agree, plastic is bad.
>I should have said that. Plastic is bad. It encourages mold growth. Paper bags are much better; air drying is the best.
My experience has been that immediate sealing and leaving the piece in open air works well. But the environment may be a big factor here. I store the pieces in a pole-barn shed that gets pretty warm when the sun is shining - 15-20 degrees warmer than the outside air. It acts like a solar kiln and things dry quickly. Your climate is more humid, so things stay wet longer and the mold loves that. (I lived in Delaware for many years.)
As a side note, I boiled a bunch of oak and walnut platter rough outs last summer and paper bagged them. They developed a lot of surface mold before they dried enough to stop the mold growth. I did a couple of small blanks in DNA and they didn't have any mold.
Yup Re: I agree, plastic is bad.
GaryG in MD
>Yeah, you really dry them quickly that way. I'm surprised you don't get some cracking. I've been waxing them and drying them very slowly in my wine cellar. Even with a dehumidifier running, they still tend to mold (some more than others). I think boiling and DNA are important stops, but, of course, these are a bit more labor intensive -- plus the associated surface discoloration. It's always something. ...Gary
Jim King
>Mix swimming pool clorine in a strong soloution and put the fresh blanks in it for a two or three days and then dry them stickered with a small amount of air movement. Cheap and easy. The small amount of air movement is as important as the chlorine.
Re: Jim King, are you
Allen Neighbors
>trying to make me eat my heart out, with that picture? :)
It worked!
Bob Fawcett
>Many of us use chlorine bleach in our swimming pools. Its cheaper than the stuff labeled for swimming pools and actually does a better job (in the pool). Just by storebrand bleach (get the unscented plain variety) and dilute it some in water.
Dave Winters
>Cool- We have a Spa - They sell us Clorine Concentrate, very expensive, especially compared to laundry bleach. Never thought of using bleach instead of the Concentrate Powder. I have always wondered if one could substitute other,cheaper chemicals instead of their hideously expensive stuff:
-Something called Shock
-PH Increaser
-PH Decreaser
-Total Alkalinity Increaser
-Some blue liquid called Water Clarifier
