Where's the Point?
Where's the Point?
Where's the Point?
>I submitted this "tip" to the AAW Journal, but they had others they liked better so I decided to post it here.
Any of you who do hollowforms (jars) by hand (rather then with a captured "system") will appreciate how hard it can be to know where, in the vertical axis, your cutting tip is located; cutting above center leads to catches and busted pieces, too low and you get no cut, so locating the cutter in the "sweet spot" is important but hard to do just by feel.
I solved this problem by epoxying a level bubble on my tool handles after I picked up a dozen or so at 2/fer in a $1 store kind of joint. You can even fit one on a Stewart / Pencil arm brace rig if you use a spring clip.
Use the bubble to set your tool rest height to hold the tip at dead center and then you'll always be able to know whether you're up down or even when the boring bar tip is invisable inside the form. The black line on the handle lets me know if my cutter in slanted to one side or the other.
Hope this helps.
Re: Where's the Point?
Bob Moffett
Bob Moffett
>Very good tip. Thanks for posting it.
Brian Hahn in SW Wisconsin
>That's a good idea Mark...
But, how do you keep from accidentally breaking the level off the handle? I'm sure I'd loose mine within a week.
Steve Russell
>Hello,
To keep from breaking the level off, you can simply rout a groove and inlay it into the tool handle. That's what I did several years ago on a handle and it works well. Good luck and best wishes in all of your woodturning endeavors!
Steve Russell
The Woodlands, Texas
>Brian,
Look closely at the pic and you'll see the vial is glued into a notch. I also rough up the bottom part of the vial for better glue grip. Mine have been on there for more than a year.
mm
THAT'S why
>they didn't publish the "tip," it had already been invented (or discovered) by others.
Well, it's good to publish it anyway.
mm
Re: THAT'S why
Arch
>Hi Mark,
Yep, it is good that you published the tip & pic. For me, and I bet most turners it's not a REpublish. At least I haven't seen similar published elsewhere. Whether I use it or not, thanks for putting it in print.
I reckon that not many truly original woodturning related inventions or adaptations have been published by AAW or anywhere else.
Arch
Bill Neddow
>Thanks for the tip, Mark. I, for one, have never seen it anywhere else. Excellent idea.
