Resin pen
Resin pen
Resin pen
eaglesc
>This is a "wrapped" resin pen made from polyester resin felt and CA.
Re: Resin pen
Re: Red Beauty!!!
Allen Neighbors
Re: Resin pen
Re: Resin pen
Tommy Holmes
>Very nice color. I don't know of this process. Can you tell me what it is?
Re: Resin pen
Re: Resin pen
HarryB in Kukpsville
>I made a pen similar to this using string and CA. Put washers on either end of the brass tubes and held them in place with a bolt and nut that went completely through the tube. Then wrapped it with string and soaking it with CA as I wrapped. Not a very pretty pen but one that got a lot of interest. If you have a friend who makes or repairs fishing rods, he may be able to show you how to make some of the wraps used with different colors of thread.
Re: Resin pen
Re: Resin pen
eaglesc
>After using a bunch of materials with CA to make a pen,
Denim(Thus not paying the exhorbitant price of $10.00 for a 5/8ths square by 5 in long pen blank )
Butchers twine sisal rope, cordage from Wally world, Ribbon from Wally world and other "wrappable materials" that bonded well with CA I wanted tomake a pen out of something that resembled a snake skin.
There is no challenge to turning something encapsulated in plastic so I tried a snakes skin overlayed on a wooden core but that too gave me frustrations.
At a local crafts store I found a piece of felt that had a python pattern on it.I wrapped it around the tubes and found that it got quite hard.When it turned it had the appearance of an acrylic blank after I wen through the micr mesh process.
There were voids that needed filling but I wasn't out much for the felt and it did not take much CA.
The process is straight forward.Turn two "fids" that are tapered and fit your tubes.
I put one in either the Beall chuck or a Jacobs chuck the tube comes next and the other fid goes in the live center and the other end of the tube.
It doesn't have to be tight just support the tube so you can revolve the hand wheel.
Cut strips of felt from the hobby store and wrap "barber pole style around the tubes
I feed the fabric from left to right from the bottom after securing one end of the fabric with a drop of thick CA.(scuff the tubes first)
After you have wrapped the tube,saturate drop by drop with thin CA.
Add enough wraps as necessary to make the diameter larger than the diameter of the pen you want to make.
If you wish you can turn and sand to a uniform diameter and add more cloth.
Though the first attempt did not look anything like a python it came out pretty neat.
Here it is on the original fabric.
Re: Resin pen
Re: Resin pen
Tommy Holmes
>Eagle, you continually to amaze me with the materials you work with and how you turn out such great pens. Thanks for sharing.
Re: Resin pen
Re: Resin pen
Jack Savona
>Even though I don't make many pens (I use ordinary wood), I find that your experimentations in creativity and exploration inspire me each time I view your work. Keep 'em comin'!
