Husky 345-E or Stihl 250 easy start
HeatherA in Alaska
>Hello, I am in the market for a new chainsaw. One of the most important features to me is easy starting. I really like the stihl 250 with easy start but also read about the husqvarna 345-E that also says it has a spring asst. starter. Anyone tried the husqvarna easy start? How does it compare with the stihl easystart? This saw will be for occasional use for turning blanks, mostly birch. I hate to spend almost $400 for the stihl if the husky will be adeuquate for $280.
Thanks,
Heather
Re: Husky 345-E or Stihl 250 easy start
Jim Swank
>Every time I've tried to save a few bucks buying a substitute for something I "really liked" I've regretted it. Arrange to try both if you can, then buy the one you "really like" if there is any way you can.
Wilford Bickel
>I have a Husky 350 that I bought this year that has a decompression button on it. IIRC without it in my hand, you push the button on the top of the cylinder in and it allows the cylinder compression to go way down making it much easier to pull to start. When you get it cranked - usually the second pull - the button pops out and the engine goes to full compression. I love this feature on my 350 and am glad with my bad shoulders the store manager I trusted advised me to buy that saw over the bigger rancher!!
Barbara Gill, Remlik VA
>I don't have the easy start but I never have had a problem starting a Stihl or Husky both larger than what you are looking at. Carole Valentine has the Stihl easy start I think. Are you sure that is the only difference between the Stihl and Husky? It seems like there should not be that much difference between the two.
Russ Fairfield
>The only difference I could ever tell is 1-pull vs. 2-pulls to start when they are new. As the saws get older, it becomes 2 vs, 3, with the Stihl always requiring one more pull that the Husky. Other than that, I have never found a great difference in the saws themselves.
Buy it on the price and the dealer reputation. Look at what the loggers and other tree folks around you are using. Different areas will prefer different saws, and that is usually based on the dealer who gives the best service when you need it. If it is based on one or the other being the only dealer in the area, the saw of preference will change if the dealer changes which saw he sells.
I bought a Stihl-026 with a 20" bar about 15 years ago. Since then I have worn out 3 bars and I don't know how many chains. It still starts on the 3rd pull, and it has never been back to the shop for repairs. Obviously, I would buy another Stihl if I wanted to replace it or get a bigger saw. The initial purchase was based on the dealer.
Re: Compression releases and springs
Russ Fairfield
>Personally I think that compression realeases and helper springs don't do anything for a saw of this size. All they do is add complexity where it isn't needed, and they are just one more thing to go wrong or break.
Disagree
Wilford Bickel
>Russ,
With major medical problems in my shoulder I have to disagree with you on the decompression. It makes my 350 easier on me to crank then the smaller Husky 145 I have - it does work. Just a matter if you need it or not.
Re: Disagree
>Can't say how it works on chainsaws but I had compression releases on my dirt bikes and they worked wonders and never caused any problems.
OTOH
>I had a spring starter on a lawnmower once. POS was always busting or slipping a cog. Service dude always cussed it.
Compression release is great, however. Makes for easier and SAFER starting because you're not putting as much force into the machine to move it around.
Hated that damn mower. Kept looking for big rocks to hit |;-}}}
mm
Keith Tompkins
keith tompkins
>Russ...028 Super is what I have 19 years, 6-8 cords of firewood a year plus all my blanks, classes, etc. I cleaned the carb once, couple of plugs, 2 bars and a few chains...that's it.
I have both
TDaniel
>my big 066 Stihl does not have the compression release but I sure wish it did! That big sucker will jerk your arm out of the socket when it kicks back. On my smaller saws I have only one of 3 that has the compression release and I seldom use it because there isn't a lot of difference. Before buying you should try both.
Re: Disagree
Barry Turner
>My Stihl 361 has a compression release....and it works quite well. It makes the engine much easier to turn over. The instant the engine fires the button pops out and you are back to full compression.
