hollow form drying
hollow form drying
hollow form drying
ryker acuna
>How does one go about drying a wet hollow form? I have my own technique of wrapping it in newspaper and then in a trash bag with alot of holes. Set it in the garage rafters for 3 months and its ready to finish. However here is the question, all my hollow forms done this way always warp. Some almost to unpresentable and some less. Is it the wood or is it my drying method? Anyone have any input. My walls I think are pretty even throughout and I usually turn midsize to about 1/8 or max 1/4". Thanks for the help.
Re: hollow form drying
adrien
>the rafters in an uninsulated garage can get awfully hot. I wonder if there isn't too drastic a switch from a slow dry in the bags to a dry sauna with quite high temperatures in the day time?
Bob Moffett
Bob Moffett
>Are your hollow forms cross grain or with the grain running lengthwise? On my cross grain ones, I put then in a paper grocery bag full of shavings and let them dry for about 5 - 6 months in the basement. If you don't have a basement, a crawl space or on a concrete floor would work. They will warp some. When I tried drying bowls in the garage, I had several crack probably due to the heat. I leave mine probably about 1/2" thick. On the one turned with the grain running lengthwise from top to bottom, I turn them to 1/8" - 1/4" and go ahead and finish them. I put finish on the outside and leave the inside unfinished so the moisture can escapeand have had very little trouble with the ones that are turned with the grain running from top to bottom warping. Hope this helps.
Norm Smith in Nova Scotia
>I soak mine in alcohol overnight, put it in a paper bag for a week than on a shelf for another week and than finish it. Works for me.
ryker acuna
>Norm, I have heard of alcohol drying but never tried it. Would a 5 gallon bucket with a lid work? Do I submerge the turning completely and do I leave the lid off so the moisture escapes or leave it sealed so the alcohol does not evaporate? Any advise would be great from anyone out there. Once again this site has given me insight into new techniques, thanks alot.
Alcohol Drying *LINK*
Charlie Anderson
>Dave Smith who post here from time to time developed this method.
Denatured Alcohol evaporates quickly. I asked a scientist friend if he could tell me how to determine how much alcohol and how much water I have in my bucket. He said if I just removed the lid for a time, I'd have 100 percent water.
Dave Smiths Alcohol Blog
