Technique for Drying a large Platter??
Andy DiPietro
Andy DiPietro
>In PIC2 of my posting below �Gloating � Walnut Slabs Etc.� I have a large walnut crotch which should yield an 18� platter blank when I turn it. It is 2� thick right now.
1. Is it better to turn it round and thin it to 1.5� thick and wax seal it? This would dry faster.
2. Or Trim it on the band saw and seal it. Then turn it when it dries? This would leave more material for warpage.
Suggestions please.
Thanks again
Andy D.
Re: Technique for Drying a large Platter??
Jim Swank
>Thinning it from 2" to 1 1/2" won't greatly decrease the drying time. Either rough turn it to no more than 1" thick and seal or, or trim onn the bandsaw and seal it. In between is just not worth the extra trouble.
Richard Allen
Richard Allen
>What terrific luck. That walnut crotch is going to look GREAT.
Anchorseal, set the blank aside to dry in a cool, dry location with good ventilation. It is also a good idea to inspect the wood every day for a week, every week for a month, every month for a year...
Give it a couple of years to dry.
Please note that crotch wood will move even when it's dry. So your usual procedures when working with reaction wood is a good choice. But that is a long time from now.
Barbara Gill, Remlik VA
>I only use dry wood to turn plates/platters. I let the wood dry in board or plank cuts first. Then if space ia a problem or when I want to have a supply of plate/platter material, I cut the blanks round and let stand until I am sure they are dry.
>Andy I usually turn dry wood for platters but I got some good walnut burl a while back. I cut it into platter sizes and coated all sides with an ample amount of Anchor seal. It's drying quite well but is going to take a while. It's probably been 8 months so I think I might turn one of them just to see if it will warp.
Gary Evans Tallassee, TN
>Hi Andy,
You've gotten good advice here on drying, but if you want a little instant gratification with one of your slabs, you can turn it to finish while green, clamp it between two pieces of plywood and allow it to dry without warping.
I had good luck with a camphor platter that I turned green. I actually persuaded it back flat after it started to potato chip. I don't think I would use this method on the crotch section. As someone mentioned, crotch wood is a little too reactive, though walnut is pretty darn forgiving of drying stresses normally.
Let me know if you want more detail on the clamping method.
Gary
Andy DiPietro
Andy DiPietro
>Hi Gary,
Your technique sounds interesting. Like you said I would not use it on a crotch blank but I may want to try it on a straight grain blank. Please send details.
Thanks
Andy DiPietro
>Hi Andy,
The setup is two pieces of 3/4" plywood and some way to force them toward each other. I've seen a sophisticated setup that used carriage bolts and wingnuts, but I had a bunch of kwikclamps laying around, so I just used them. With a dead green platter, I would drill a few ventilation holes in the sheet that goes on top. Mine was already drying, so I didn't bother with that.
I was fortunate to have some rubberized sheeting that is sort of a mesh. I used a piece of that under the bottom of the platter and along the top edge to allow enough airflow that the wood doesn't get moldy.
I think I let mine set for about 4 wks in the clamp before I took it out. You probably need to let yours sit a little longer, but at least you get the gratification of being able to turn some of that beautiful walnut as soon as possible.
Here is a pic of my setup.
Gary
Another picture of my setup
Re: The old methods still work, and....
Russ Fairfield
>....and sometimes they are still the best.
The old method of burying the wood in a pile of shavings or sawdust still works. The moisture release from the wood is slow and absorbed by ther sawdust; and the weight of the surrounding pile reduces warping. The only disadvantage is that the sawdust has to be turned over every few days to prevent mold and mildew stains from forming on the wood.
This is drying the wood by absorption of the moisture into another medium, and it really wprks. It works better than than open air drying, coating the wood with a wax or other material, or putting it in paper bags to deduce the evaporation rate from the surface. And it works better, smells better, is not as messy, and a whole lot safer than soaking the wood in alcohol or the dish water.
The best of all drying methods for problem species that are likely to warp and crack as they dry is boiling the wood in water to relieve the internal stresses, and then burying it in the absorbant material to remove the water.
There are a lot of other materials that work better than sawdust. The only advantage to sawdust and wood shavings is that they are free.
I discovered that burying the wood in the grain bin was an excellent way to absorb moisture, and that wheat worked the best of all. The grain provides 100% contact with the wood, the dry grain absorbs a lot of moisture without any degradation, and the weight of the pile kept the wood reduced the movement of the wood. At the time it was free.
Somewhere. many years ago, I ran into a woodturner who turned butter and bread bowls from Pine and Douglas Fir, and he used corn meal. It absorbed the moisture, and it could be dried and reused. He laughed and said he could also eat it for breakfast.
Industrial Oil-Dry is an excellent absorbent material. It is also available as kitty-litter at a higher price. The only problem is that it is a little too "excellent" and the wood can dry too fast. It works best if the bowl is dripping wet with free water. That makes the material in contact with the wood wetter, and that slows down the absorption rate. A thin coating of wax will also solve the problem of "too fast".
