free standing tool rest
John Pickett
>I am thinking about trying to make or acquire a free standing tool rest. I know there are some effective homemade rests out there. Anybody here have one (I hear that John Lucas made one). Pictures please :)
John Pickett
Re: free standing tool rest
>John I'll post photos of mine tonight after my bike ride.
here's the photo
>Here's my tool rest. It needs more weight. I used a truck wheel and added a 3/4" by 6" piece of steel over the center hole and then use pipe and Pipe fittings to finish it off. I put some leveling feet. I think I'm going to pour concrete in the wheel to make it heavier.
It's just light enough that if you don't have absolutely perfect tool control it pulls the tool rest into the work, or at least causes some vibration which makes clean cuts difficult. It would work well with a scraper.
I'm also thinking about making a sort of hinged elbow that attaches to the lathe and goes to the tool rest pole. This is similar to the Vicmarc free standing tool rest. I think it would add a tremendous amount of rigidity to the tools rest.
Re: here's the photo
John Pickett
>Thanks, John
Here is my version
steve antonucci
>My headstock can rotate, so I made this out of some leftover 2x stock and blackpipe. cost about $12
Since the toolrest inserts into the regular banjo and the freestanding leg only holds up the end of the bar, it's pretty stable. (doesn't tip) I could rebuild it much "beefier" if I wanted too, but it works well enough as is.
The base is a simple X screwed into the bottom. I filled it the blackpipe with sand to dampen the vibrations, and sealed the end with a wooden plug that I hammered in. For scale, the platter on my Nova is 23" across.
Steven
John Pickett
>Does this bolt onto the floor? it looks like there are bolts.
Re: Here is my version
John Pickett
>Thanks. And no welding. Even I could do that! :)
>No, you need to be able to move it around for different cuts and shapes. If you can find a photo of the Vicmarc outboard turning rest you will see what I think is the best design for "free standing tools rests"
John Pickett
>That's what I thought, so I was confused when I thought I saw Bolts on the base. Thanks for the clarification
