Spalted Walnut Crotch Hollow Form
Andy DiPietro
Andy DiPietro
>This was another challenge and save. The crotch sat outside for two years and dried and cracked. I band sawed it into a cylinder and soaked it in water for two months. I was able to turn away the cracked area and hollow it to 1/8� wall. This piece is 6 �� dia x 8� tall with a 1 �� opening a 2 �� base. Critiques are welcome.
Thanks
Andy DiPietro
Re: Spalted Walnut Crotch Hollow Form
Andy DiPietro
PIC2
Andy DiPietro
Bob Moffett
Bob Moffett
>Andy,
That is a spactacular piece! You really nailed the flowing curve from top to bottom. Any collector would be proud to own this piece.
Andy DiPietro
Andy DiPietro
>Thanks Bob, my wife is the collector on this one.
Allen Neighbors
>Andy, this is beautiful wood, beautifully turned. Nice form and finish, too.
Of course, the inside is sanded to 25000.... :)
Speaking of soaking, I'm trying that now on a chunk of pear, I think.
I forgot to change the water... Pheewww!! :)
Steven Antonucci
Great finish on a tough wood!
steve antonucci
>I've never ever gotten a good finish on walnut, so I commend you.
I would have liked to have seen the foot tuck in a bit at the bottom to give the piece a bit more lift. I think Russ referred to it as "growing out of the table". As a turner, I call it "parted off".
Great flowing curve all the way down, too. How come you didn't end up with the feathering that makes me tolerate walnut and try it once in a while? In a piece that size, I expected to see some.
Steve
Andy DiPietro
The key is good sanding!
Andy DiPietro
>I finished this piece with 5 coats of Waterlox and Beall buffed it. It has a very glossy finish. The pictures do not due the piece justice. I was asked the same good question about the finish at my club meeting the night before. The key to getting walnut and other hardwoods to shine is sanding. I power sand at slow speed (50 rpm on Lathe) in both directions CW & CCW. I start with 120grit on a good day then 150, 180 then 240. Then I switch to hand sanding with the grain on the lathe with 240, 300, 400 and stop at 600. Between coats of finish a rub the piece with a white 0000 abrasive pad. If the finish is not smooth enough I lightly sand with 600 then add the next coat.
I should have curved the bottom in more and made a smaller foot. I was having a lot of trouble hollowing the bottom since the wood was so dry. So I cut off the piece to soon.
I was hoping that I could get the crotch feather to show more. I think if I had made the diameter smaller this may have happened? If someone knows the trick to doing this please let me know.
Thanks
Andy DiPietro
Bob Moffett
Bob Moffett
>I understand that one! You really turned a beautiful piece for her. She should be proud.
