THE WOODRAT IS BACK!
woodburning unit
woodburning unit
woodburning unit
jeff myroup
>I am looking at purchasing a detail master sabre IV woodburner. Have any of you had experience with this unit? I would also like to know if it will accept different pens from other makers. Thank you
Jeff
Re: woodburning unit
Molly Winton
>Jeff, in my opinion you will be better served purchasing a Burnmaster. It's almost half the price, more powerful, and can accept any commercial pens on the market, no matter the type of plug used. The Detail Master will only accept the 1/4" phono plug pens, which exclude any made by Razertip or Optima. You can purchase the Burnmaster through Woodcarver Supply (www.woodcarversupply.com).
*Just my opinion, no affiliation with the manufacturer or vendor.
jeff myroup
>Thanks Molly! I will give them a look.
Walt Ahlgrim
>Last week I bought a Burnmaster Eagle brand new on eBay no one else bid so it was 85.00 + S&H. They have another up now item# 320125330266
Got 4 Optima pens (http://www.carvertools.com) PH6, PH10, PH19S and a custom coil-stamping pen. The last item is not listed on the website works great and a lot less work than the homemade versions and only 5.00 more than the stock pens.
Russ Babbitt Jr.
>I have the Sabre IV unit and it works just fine. It does work with other manufacturers pens with adapters available. I made my own adapter with parts from Radio Shack. Burnmaster came out after I got my DetailMaster. Like Molly says their price is very good with some very good specs. I would look at Burnmaster today if I didn't have the DetailMaster.
Ed in Sptbg.
>I'm also interested in the Burnmaster units. Would someone tell me the advantage of the two-port model vs. the single-port? Thanks.
jeff myroup
>I checked out the burn master and that is the way I am going to go. It also has 30 more watts. Now I just have to decide on the pens I am going to get. Thanks for all the advice.
Jeff
Molly Winton
>Ed, the only advantage of getting the unit with two ports rather than one, is not having to unplug and plug your pens when you want to switch from one style to the other. You cannot have both pens hot at the same time, but rather switch power from one to the other with a toggle switch. It's primarily a convenience factor when using more than one pen on any given design you are working on.
Russ Babbitt Jr.
>I like the DetailMaster one piece vented pens. They can be adapted to work in other units.....
jeff myroup
>Russ,
do you put anything over the pens to help keep them cool? They look like they get very hot.
Jeff
