lathe tools
lathe tools
lathe tools
Scottc
>I have purchased a new lathe that will arrive later this week. I am a new tuner. The first project I want to do is turn some legs for a table. What is considered a good starter set of lathe tools? Are Sorby tools worth the money? What about other accessories?
Thanks in advance.
Re: lathe tools
Re: lathe tools
>Roughing gouge - go for a larger one (1 1/2" as opposed to a smaller one).
Parting tool
Spindle gouge - might consider a large and a small one.
Skew chisel - again, I like a slightly larger one.
Round nose scraper
Flat or square scraper
Sorby has some good tools as does Crown and others. I've got a mixed bag of Crown, Sorby and Delta.
Re: lathe tools
starter set
TDaniel
>You might want to start with a cheap set from Harbor Freight. Their HSS set is actually pretty good. The parting tool in the set is no good as a parting tool but you can regrind it into something else that is more useful. Sorby has a very good parting tool, actually they have about 3 different ones, and they are all good. You can learn how to sharpen on the cheap set and they will get you started and then you can add better tools as you see what you want/need. The HF set is about $40 for 8 tools.
Re: lathe tools
Steven Antonucci
The bare minimum
steve antonucci
>I have dozens of tools, but really only use a few on a regular basis.
The tools I can't live without:
Bowl gouge
Parting tool
spindle gouge
Ellsworth style hollowers (Homemade)
skew
I don't really use my roughing gouge that much (I rough with a bowl gouge). I also have some scrapers that I will use once in a while to remove tool marks on the inside of a bowl or a box, but you can also "make them" homemade from a teardrop cutter and some round bar stock too. Bedan rarely comes out.
Steve
P.S. All of my tools came in an Ebay buy and were Sorby.
Re: lathe tools
Re: lathe tools *LINK*
>For spindle turning you nailed it. I like my Sorby tools very much but you might also look at the Packard tool from Packard woodworks. They are great folks to work with and have other tools as well.
http://www.packardwoodworks.com/
Re: lathe tools
Re: lathe tools
Russ Fairfield
>Get a copy of Keith Rowley's book, "Woodturning, a Foundation Course". It is the one with the green cover. It is available at Woodcraft and fom all the other stores and catalogs, and it will be the best $20 you ever spent. It will answer almost every question you have and a whole bunch you haven't even thought of yet.
Re: lathe tools
Great Book
Tony - Memphis
>The video is good too. I started with a 3/4" roughing gouge, 1/8" parting tool, 1/2" spindle gouge, and a 3/4" or 1" skew. I do spindle work for furniture. I went with the Sorby tools. You'll be using them for many years, so consider that. Enjoy your new lathe.
Tony
Re: lathe tools
Re: lathe tools
Don Orr
>The best piece of advice I can give is Listen To Russ Fairfield !!! He is very knowlegdeable and experienced and extremely generous with information. He also tells it like it is which I like a lot. His book recommendation is right on as it is probably the best, most complete single resource available.
The other piece of advice would be to Practice, Practice, Practice. Just like any other activity-music, sports, etc.-practice will get you farther faster. The converse of that is that prcticing bad technique will hold you back just as much.
Good luck and have fun. Stop back in if you have more questions or just to say Hi. And remember to show us how those legs come out.
Re: lathe tools
handle comfort
Dave Belser
>Nothing wrong with Packard tools, but I learned on Pinnacle tools that generally come with longer handles. When I recently purchased a Packard detail gouge, it came with a 10" handle that was just way to short and skiny and just felt awkward to me. I ended up splitting the handle off and turning one more to my liking - My fault for not reading the description better!
Not sure if there is a consensus here or not, but my preference is definitely for longer handles, perhaps because I learned on them.
Re: lathe tools
Russ Babbitt Jr.
>What eveyone said is good, but if your new to turning the tools are just part of what you will need. A system for sharpening is a must. Look for a club in your area. That would be the best place to start for any advice......
AAW Chapters
Re: lathe tools
Re: handle comfort
>I like longer handles and when I can I buy tools unhandled so I can make my own. Anywhere from 12 to 16" is the norm but I have a 5/8" gouge that I use for heavy roughing that stands 5 feet tall total.
Re: lathe tools
Re: Great Book
>I just finished the new Finewoodworking book "Woodturning basics". It is excellent for the beginner. It covers a lot of different styles of turning and is mostly written by Richard Raffen and Ernie Conover and a few others. It is a very good book for beginning turners. Not that I'm an expert but I found very little that I would teach any differently. This book should be sold with a new lathe so you can avoid many of the frustrations.
Re: lathe tools
Re: lathe tools
Doug Thompson near Cleveland
>Any tool you buy needs to be sharp. The Wolverine and Vari-grind is IMO the best on the market plus it's a one time buy. Good luck I'm sure your head is spinning by now.
Post some pictures!
Re: lathe tools
Re: starter set
Bill Crommett
>I am happy to know that Terry is preaching the same theme I have been harping on for years: Buy cheap and learn to grind, and then get better tools in the configurationn you find you will need.
Re: lathe tools
Re: starter set
>I agree to a point. I also think it's a good idea but you need a good teacher. Some of the tool sets I've see come so poorly ground that the beginner can't really use them successfully. Once I've regound them to a usable shape the newbie usually has pretty good success resharpening them and of course learning to sharpen correctly.
Re: lathe tools
Re: Great Book
C.W.Stivison
>That is a really good book for us newbies
CW
Re: lathe tools
Re: lathe tools
C.W.Stivison
>I have not been turning very long but I see no use for a beginner to buy a skew.
CW
Re: lathe tools
Re: handle comfort
David Breth
>For rough turning of telephone poles.
Re: lathe tools
Skew? Yes...
Ron McKinley
>you can open paint cans with it! GRIN .....Ron
Re: lathe tools
Re: handle comfort
Wally Dickerman in Arizona
>For all heavy-duty tools I want long handles. 18 inches or more. I use them tucked against my side and move the tool with my body. Much safer and more stable. For spindle turning tools, over-long handles get in my way. My first bowl gouge, a Sorby, purchased in 1982 or 1983 has a 12-inch handle. Way too short, but who knew then.
Wally
Re: lathe tools
Re: lathe tools
Allen Neighbors
>I've finally learned how to use a skew!! I'm a little shaky, but I reach for it quite a bit, and I'm getting better. It's an old Crapsman that I've had for years, and I've just about sharpened it away. The length from point to handle is just shy of 3 inches. (Waitin' on Doug to get his ready for the public.)
Watching Ruth Niles in Georgia finally paid off for me. I can still remember her demo. Thanks, Ruth! You're a Skew Artist! :)
Re: lathe tools
Skew?
Ron in Drums PA
>I was turning for one week when Bill Grumbine showed me how to use a skew.
Re: lathe tools
Re: handle comfort
>I started turning before captured boring bars. The way turners turned large stuff was to have very large long tools to counter the forces from a big spinning chunk of wood. My friend Joe Looper had a lathe with a 54" swing. He had a whole set of tools over 6 feet long.
My understanding of how the boring bars got started was first the long tools which got quite heavy so they propped the end up on a stand to support it. This eventually led to the captured secondary tool rest and then to shorter tools.
Re: lathe tools
Re: lathe tools
>I think beginners need to learn to use the skew, unless they only turn bowls. I spent too many years trying to turn long tapers and long flat areas on spindles using hand planes, belt sanders, scrapers and other ineficient ways of accomplishing what a skew does easily.
Then there's using the toe down to add details and crisp areas to bowls. I do this often when I have beaded lips on the bowls or want really crisp lines between the foot and the bottom. It's quite safe the way I do it because you have the handle higher than the cutting edge.
Re: lathe tools
Re: handle comfort
>I have a telescoping boring bar. opens up to 5 ft long, weighs 9 lb. ....used with a rail behind the turner. I havent used it in years, but I turned hollow forms a couple of feet deep with it.
Wally
