>I picked up a large Holly log from a member of our Club Sat. I've never worked with it and wonder how stable it is. He has both ends waxed and so far I see no checking started. How stable is this wood with the pith still in for hollowing? Should I cut it on into blanks and wax it with the pith out. Any other good suggestions based on experience would be appreciated!
>Come on folks - surely someone has worked with Holly! See what I get for letting the wife attend the club meetings with me and want a special piece of wood!!!
>I have turned quite a bit of it. So far stability has not been as much of an issue as staining. In this heat and humidity holly will quickly blue. I have had the best luck in warm weather with turning per Dave Smith's directions and soaking in denatured alcohol. It is a very nice turning wood without much character. It is also the only one I use a water base poly on. The one I use is very thin and will soak into the wood. Since holly really does not have a great deal of figure the poly is not an issue.
>I assume it is green wood. You do need to take the pith out and cut your blanks. I have had good luck boiling holly blanks, letting them dry for a day or so then storing them in the freezer. My biggest problem is that here in VA where it is fairly warm and humid, the blue-gray staining will occur almost as soon as you cut the wood. The boiling and freezing seem to help that. Some people don't mind the stain, but I prefer my holly white. If left in log form outside, it will rot really quickly. DAMHIKT! It is a wonderful wood to turn.
