Lathe Motor/Controller
Peter Toch
>My turning club has decided to rebuild the club lathe stand and replace the single speed motor with an electronically varible speed system. We are looking at a 1-1/2 or 2hp, 110VAC, 3-phase motor and a controller which will have 110VAC, single phase input and 110VAC, VFD output. Looking for suggestions on where to cost effectively obtain these and any experiences that you may have had in putting together such a system?
Peter Toch
Blue Ridge Woodturners
Re: Lathe Motor/Controller
Bill Turpin in WNC mountains
>I have never seen a 110 volt 3 phase motor. I believe that you will have to find a 230 three phase. You will need 230 volt single phase to generate 230/3 phase.
Bill
Russ Babbitt Jr.
>Yup, what Bill said. You could consider a 110vac controller ouputing 90vdc to a DC motor.
Oneway 1224...
Peter Teubel
>...has 110v input and (I assume) 230v 3-ph output.
Re: Lathe Motor/Controller *LINK*
>I believe powermatic makes a lathe with 110 3phase controller. I bought one from the people listed below. It wasn't hard to install. A friend bought just the electronics to go on an older motor and we couldn't get the two to work together. Neither one of us are electronics or motor experts however. He ended up buying a motor from Dealerselectronics to go with the controller.
http://www.dealerselectric.com/
110v single to 230v three phase VFD
Curly Smith
>You might also try, in addition to dealerselectric mentioned above, driveswarehouse. The following isn't exactly what you're looking for but they might have something that would work. However, three phase motors aren't very expensive. Unless you have a compelling need to use the existing motor you might be better off buying a motor and a controller package, if for no other reason than it greatly expands the number of options.
Variable Frequency AC Drives - 110V Input, 220V Output
