Chain sawing blanks..hard work!
Joe Pack
>After several months of cherry picking sections of downed trees in my area, I started sawing some into blanks today, per the video clip on Bill Grumbine's web page. The typical section was 16"-18" in diameter and 18" long. After sawing the first one on the ground, my back was throbbing (back trouble for a loooong time), so I made a stand out of plywood on top of some sturdy saw horses....no more bending over, but I did have to lift the sections onto the stand.
My biggest problem, though, was ripping with a saw designed for crosscutting. I have a 20" cut Poulan Pro 295. My blade was next to new. Per my understanding of the process, I tried to keep the cut at an angle, about 20-25 degrees, instead of a true rip; the idea was to keep a minimal amount of blade in contact with the wood since a true rip bogged the saw down to the point of stalling.
Overall, it felt like I just did not have enough power to cut properly. The slightest "goof" on the angle, or too much bite, bogged the saw down so much that I had to back off and keep working the trigger to keep from stalling out. If this had been a car in the driveway, I would have sworn a 16 year old was showing off for his buddies!
The end result was 10 very good blanks of maple, spalted maple and cherry, but I have easily 5 times that much wood to go! Having watched Bill do this one time, I know I should have spent one hour instead of three doing this.
You get the idea, so, now, the questions: (1) What can I do differently to make better cuts?
(2) Is my saw just too underpowered to do what I want to do? (3) Should I invest in a true rip chain, particularly if my saw is smaller than ideal? (4) Should I just call you folks and offer you some good firewood? (5) How long will it take for my back to get better?
Thanks. I'll read replies tomorrow...this sore old man is going to bed!
Re: Chain sawing blanks..hard work!
20-25 degrees laying on it's side; not quite flat
Joe Pack
Re: Joe, I didn't know you could
Allen Neighbors
>buy a rip chain. I've always just cut my blanks with my normal chain that I purchased for my Stihl 20". I also learned from Bill's Webpages. Mine cuts through almost any log like it was butter. If it gets a little slow going, I sharpen the chain. (I use a Dremel tool and the stone for my chain)
I suspect your chain isn't as sharp as you might think.
no ripchain needed
TDaniel
>a standard chain should work just fine. If you were doing 50 or 100 I would suggest a skip-tooth chain. Like Al said, keep the chain sharp and it should do the job. It does take a lot of power to rip quickly.
My experience...
Peter Teubel
>I find that ripping is all in the technique (assuming a SHARP chain). I don't "angle" the cut. I just cut straight down with the log laying on the side (NOT on end). Here's what I do:
#1 Keep the chain speed up.
#2 Gently lower the bar thru the cut....sometimes not even the full weight of the saw.
#3 Keep the shavings clear of the exit. If you are cutting on the ground, you'll have to clear them away frequently. If you're using some sort of waist-high stand, you clear them away less frequently.
#4 Keep the chain speed up.
My big saw rips better, but I can rip quite easily with even my MS170.
- Pete
PS. I had 2 of those Poulan 295's and toasted them both in 6 months. Borrowed a friend's Stihl for a week, and the rest is history.
Re: My experience...
nailshooter
>Like the others, I would look at the chain for sharp teeth first. The second thing I would do is get a better chainsaw if I could. I bought a 24" Husky and can cut large oak faster than I could cut green ash when I had a Mac.
The first day I used the saw I cut down a large live oak that was about 36 inches in diameter. Me at the saw and one other person cut the tree up and had it in fireplace lengths (about 3 1/2 cords!) in a ten hour day. I never would have dreamed it would go that well. I used to cut firewood as a teenager for extra money, and I learned that a good chainsaw is worth every penny you pay for it as it cuts the labor in less than half.
Pete is right; use a good chainsaw that is fueled properly and made to work, and you will sell the homeowner chainsaw at the next garage sale.
Robert
Keep the saw sharp
Brian Hahn in SW Wisconsin
>I use an electric chain saw (Makita) for most of my ripping and it has a lot less power than a gas chain saw.
The most important thing is to keep the chain SHARP.
Second, angle the blade so the shavings are short and don't clog the saw as much.
Third, elevate the wood to save your back. I use a 24" log section standing on end. (See the article in the May 2007 issue of Wood Magazine.)
Gordon Seto
>"My blade was next to new." may have been your problem. You didn't mention that you have sharpened the chain. Don't assume the chain on new saw is sharp or installed properly. My new Echo won't even cross cut the first cut; the wood smoked. I took the saw back to the store; they took the chain off and sharpened it for me for several dollars (sharpening was not covered under warranty). It cut through the remainder of the cut in seconds.
Gordon
10 Tips To Help When Chainsawing...
Steve Russell
>Hello Joe,
Welcome to my world... :-o I've always said that chainsawing logs and blanks was the least desirable part of woodturning for me. Try spending all day in full sun, with 100 degree heat and 99% humidity... That's a pretty typical harvesting day for me as I cut about 95% of my timber in the unbearably hot and humid Houston summers. I've seen folks nearly pass out from the heat, not to mention the physical exertion from a day of chainsawing.
As others have pointed out, the slightly raised 20-25 degree cut usually produces the most efficient cut on the long grain when ripping. I do not use ripping chains, but I do use alternate skip and full skip tooth chains on my Stihl 066 with the 32" and 48" bars installed. You do need a good saw with lots of power to rip quickly, but there are a few things you can do to make sure you're getting the best form the saw you have now.
1.) Make sure the chain is sharp. If you do not know how to sharpen your chain correctly, there are lots of books and even free sites on the internet that will show you the correct protocols. Also remember, you can have a razor sharp chain installed and two seconds later it can be dull as a butter knife when chainsawing. All you need to do is let the tip hit the ground, run through dirty bark, or hit an obstruction in the timber and your chain is toast. Keep several chains on hand if possible and switch out when necessary, then take a break and sharpen them if you run out. You can also resharpen the chain as it becomes dull on the saw, the choice is yours. :-)
2.) Periodically clean under the chain housing to remove accumulated shavings and sawdust. I usually do this on every second tank of gas since I've already stopped and I'm looking at the saw. I use a small chip brush to clean under the chain cover, they work well for this. Also, while you're there, clean the oil holes to make sure your bar is getting lubed correctly. Sometimes, a small chip can become stuck in the outlet port, causing a reduction in oil flow. This is bad for your bar, and it can also slow the chain speed down.
3.) Check the air filter for accumulated dust. About every tenth tank of gas, I pull the air cover off and brush any dust off the face of the air filter. A clogged filter can really bog your saw down, killing your chain speed. I usually bring a second clean filter and swap out after a few hours of cutting. If you do this, you will be amazed how much better your saw runs.
4.) Most folks never mention the rakers, or how important they are to the cutting performance of your chain. Rakers are the projections that stand proud between adjacent teeth on the chain. Their function is to help clear chips from the cut and to help regulate the depth of the cut. The top of the cutting teeth slope backwards slightly, this means that over time with hand sharpening, the teeth may be filed so low that the blade actually rides at the same level as the rakers in the cut. This can prevent the teeth from cutting even with a freshly sharpened chain. You can get a filing guides to make sure your rakers are set to the correct height. The raker filing jig is a metal channel that sits across several teeth, with slots cut into it for the rakers. If they are too high, you can file them to the correct height. Be careful to not over file the rakers, as this can cause the saw to really grab in the cut and may cause the saw to kickback. It's worth the money to buy a book on chainsaws and sharpening to make sure your saw is in top notch shape and you're working safely.
5.) When ripping, make sure the log is as short as possible for the blank size you are cutting. For example, if you are cutting a 14" bowl blank and the log section is 17", I would trim it with a crosscut to say 14" - 15" first, then do your ripping. Shorter lengths of log rip easier, so if you can shorten the log with a crosscut first, do it. It will make your ripping faster and easier.
6.) Try to cut through clean bark if possible. If the bark is obviously dirty, use a hatchet or an axe to get to clean wood before you make your cut. Yes, this is not fun either, but it's a lot faster to remove a dirty strip of bark with an axe, than to resharpen a chain dulled by dirty bark.
Body Saving Tips:
7.) Save your back! You already found out that elevating your logs makes it easier to cut, but that means that you have to get the log sections up on your cutting jig. Wear a weight belt and make sure you lift with a straight back, knees bent. NEVER lift with a bent back or you will regret it. Also, on larger log sections, try to roll them onto your cutting jig, or get a friend to help. Make a blank cutting day out of it and you will both benefit.
8.) With really large, or heavy log sections, use a come-along, winch or similar tool to get it off the ground. You only have one back and an injury can really set you back, so take care of yourself. Remember to take breaks when cutting as well. Stretch and walk around a bit in the a/c or in the shade to recuperate a wee bit, before you get back to it. Make friends with another turner and work together. It will be more fun and easier for both of you.
9.) As time goes on and if you continue to turn, consider getting a more powerful saw. Horsepower and torque is everything in chainsaws! To get the job done faster, you need a lot of power with high chain speed. Small and intermediate chainsaws can do the job, but if you want to really do it faster, you need a large chainsaw. If you will only be sawing occasionally, skip getting another saw and consider renting a larger saw, or using a friends on the big logs.
10.) Don't forget to do some stretching and flexibility exercises before you being sawing. You need to stretch your body to help prevent injuries. I usually stretch for 15-20 minutes before a day of sawing. It really helps! There are lots of sites on the internet that can show you the correct way to warm up and stretch your body prior to physical exertion.
Last but not least, remember to drink plenty of fluids... If you do not, you can easily get dehydrated which can cause lots of medical problems. If your back is really hurting, your doctor can write you a script for a therapeutic massage. Most outpatient hospitals and rehabilitation facilities offer these services. They can also offer hot pack treatments, and ice pack therapy to get you back up to speed quickly. Good luck to you and best wishes in all of your woodturning endeavors!
Steve Russell
The Woodlands, Texas
Steve, Great Tips
Clem Wixted, Jonesboro, AR
>Thi tutorial on chainsaw cutting is excellent. Thanks.
Clem
Steve Kubien
Great stuff Steve
Steve Kubien
>Thanks for all of the great tips. I am pretty new to chainsawing and this is very helpful. The only thing I would add is regarding your comments about stretching beforehand.... Never stretch when you are cold. A 10-15 walk will get the blood moving and loosen things up before your stretch. Cold stretching WILL lead to injuries (not a question of if, but a matter of when).
Thanks a heap!
Steve Kubien
Ajax, Ontario
Make It Easy On Your Saw
>What has not (I think) been mentioned here is that you can improve your saws cutting by varying the cut angle. If you run your bar parallel with the pithe, you're making the teeth pull the longest shaving possible. This takes more power and packs the sprocket housing more readily, which increases friction and heat and robs power from the cutting edge. You will improve your saw's performance if you raise the tip by about 20*. This has your chain cutting "downhill" somewhat across the annular rings rusluting in shorter shavings that clear your saw housing mush easier. The pic is an example
Hot dog I'm going to get rich...
Stuart Johnson
>No safety disclaimer.... haven't you been reading the political correct and safety thread?
Now I just have to decide if I want to cut off a foot, leg, hand or arm. Anybody know the going rates? What if I go for two?
Re: Hot dog, You're Going To Get
>Zip.
Cut your body parts off for your own account, but remember, Your Doing It Wrong" is not my responsibility nor do I have a legal duty to protect you from yourself merely because I have gratuitously illustrated a safe method of performing a task. Anybody, a-n-y-b-o-d-y, who blindly follows how-to Internet advice expecting to be protected from harm in an inherently dangerous activity is a fool, and likely a damned fool.
God protects babies and drunks, but not idiots.
peace |;-}}}
mm
Rick in Colgate, Wi
>Joe,
I believe Its your saw thats the problem. I had that exact model I bought on ebay and realized it just didnt have the power to do the sawing I wanted it to do which is bowl blanks and firewood. After a frustrating year of trying to saw wood with it the recoil broke and I threw the whole saw in the garbage and bought a Stihl and could not believe the difference in sawing performance!
PS on Safety
>Note from the photo that the following safety methods are in use:
1. Safety glasses.
2. Steel-toed work shoes.
3. Gloves.
4. Body mass to the left of the bar with the powerhead aligned with the right hip to keep (most of) the operator out of the throw zone of a kickback or broken chain.
5. Left arm and shoulder stiff with body weight shifted forward on the left leg to control kickback and provide maximum control of the fulcrum point.
6. Bar in use is longer than the piece being cut to minimize incidence of kickback from a buried nose.
7. Cutting area clear of spectators
Not in evidence but often recommended:
1. Hearing protection.
2. Hard hat.
3. Chain resistant chaps.
mm
pps This is not a disclaimer. YMMV
Well never mind. If I have to
Stuart Johnson
>be responsible for my own actions I'll just skip calling the 800-bad-saws attorney and use my chain saw with care.
On a more serious note there are so many ways one can get hurt all anyone can do is try to be careful. I read a statement one time that seems so true. "There is no such thing as an accident. There is only a series of bad choices." If you think about it that really is the way to describe any accident.
Re: Choices
>A better choice, indeed, Stuart. |;-}}
Too general a statement, I think. Many accidents occur without any choice by the victim other than having chosen to get out of bed that morning. I think a lot of accidents occur because of a lack of basic knowledge. We call someone "negligent" if they do (or fail to do) something while either ignoring a known risk of harm or failing to exercise reasonable caution in the situation. Both of those standards require some knowledge of the risk of harm in the activity.
S***, however, sometimes just happens; no choices required.
mm
Wow, very thorough! Thanks, Steve.
Joe Pack
Thanks. Figured out the problem.
Joe Pack
>Thanks to all for you many tips. After weighing all responses, and after checking my saw, I figured out the following:
1. The chain I thought was okay would not cut butter. I compared it to a new one and know what I was missing.
2. After a sharp blade, technique is everything. I now know about the former, working on the latter.
3. My saw will get me by...until I need a new one. I KNEW I should have spent the extra money on a top line saw instead of a homeowner model. I bought what I needed at the time for some trimming, so I can't complain too much. I just didn't think I would use it so much for what I now want to do with it.
4. I am too old and fat to do too much of this at one time...gotta get in better shape. Even today, I hurt in places I forgot I had. :-)
Thanks to all for the time you took to help a novice.
