A Curly Pink Ivory .....
Danny Wells
>trumpet yelper (turkey call) just finished for a lady. It also has an elephant ivory mouthpiece and a polished aluminum ferrule. It is 9" long and the bell is about 1 3/16" diameter.
Danny Wells
Re: A Curly Pink Ivory ..2nd photo
Danny Wells
Re: A Curly Pink Ivory .....
tm
>Very nice work. About the elephant ivory...
Aren't there laws against having it?
This may be a hot potato but I'm curious.
tm
Cyril Griesbach
>I believe that elephants can still be legally harvested and thus would have to believe that the ivory, when legally taken can be legally posessed.
Danny Wells
>The elephant ivory is "pre-ban ivory". That means that it was in the U.S. before the ban on bringing ivory to the U.S. from Africa. It is legal ivory.
Kind of Nit Picky, but... aluminum?
steve antonucci
>Pre-ban ivory.
Curly pink ivory.
and aluminum? I think sterling or some other precious metal might have complimented this piece much better.
Spectacular work otherwise.
Steve
Jennifer@Indy.USA
>Danny, it's a really nice piece. I love the pink ivory and the shape of the horn. I never realized that turkey calls were so big? I would think hunters would need something more compact? I'm clueless in hunting calls. I guess I too have issues with the elephant ivory. Regardless of whether or not it was pre-ban ivory or not. I just have a problem with turning and using material that use to be attached to the face of a beautiful creature like an elephant. Just my opinion, thats all.
Jennifer
Re: Kind of Nit Picky, but... aluminum?
Danny Wells
>Thanks Steve,
You have a point, however the only silver tubing that I have found in 1/2" dia. comes with a wall thickness of about 1/64" and I'm not sure that silver pattern wire can be formed to 1/2" dia. The ferrule does provide some strength at the joint where there is a tenon on the ivory.
Traditionally ferrules are brass, but I felt the silver color complimented the pink ivory better.
Have you tried Googling?
steve antonucci
>I agree that "silver" color is the right mix for this piece. If you had curly maple, you could probably get away with brass, but the pink ivory calls for "high finish".
I'm guessing that you can probably find some silver suppliers on Google if you're compelled. Platinum would really kick it up a notch :-)
Steven
Danny Wells
>Thanks Jennifer for the compliments,
I can understand how one might feel that way, but once you've turned it you would probably change your mind. It is beautiful as a turning material. It has a grain very similar to wood, comes off in shavings and sometimes even ribbons. It holds very fine detail extremely well and will polish to an unbelievable glass finish and requires no finish be applied.
The call is really not that large, only long. The mouthpiece is only 1/2" in dia. at the largest point and is 5 mm at the lip end. It has a 3/32" hole running thru the length of the mouthpiece.
Danny Wells
>Yes, elephants can still be hunted in some countries in Africa. But the ivory tusks can not be brought into the U.S.
