Found my vacuum pump!
Gary Evans Tallassee, TN
>Hi all,
As some of you know, I'm in the process of rehabbing an old store building to use as my shop, I mean my studio, and gallery.
In the depths of the dank, dark basement, we found an old compressor/condensor unit that had powered a walk-in cooler back in the old days. It's a Copeland model 55 AFC. It's a piston pump and it has it's own oil sump. Since the system had long been emptied of freon, I didn't feel bad about taking a look at resurecting this unit.
We put some power to it, but nothing happened. Jumping across the pressure switch brought the old guy back to life. I haven't had a chance yet to buy a guage, but the intake will suck your thumb down pretty solidly on the fitting. I've got my fingers crossed that it will be an ample vacuum source.
One of the best things is that the unit is located directly below where my lathe will be located, so I can just pipe up through the floor and not have to listen to the pump when it runs.
Gary
Re: Found my vacuum pump!
Bill Howatt
>I resurrected a 2 piston unit that was orginally used on a farm to cool a water vat that the cans of fresh warm milk were placed to cool them down - doubt if you can do that these days. It probably was 20-40 years since it last run.
I had to remove the head and an intermediate cast plate between the "block" and the head to get at the 2 sets of reed valves. Cleaned them and everything else up, changed the oil and it works great. Not really too noisy at all. After a short running time I changed the oil again.
Bill
>Hi Bill,
That sounds very similar to the one I have. It's either a twin-piston or it has one very large oval shaped one. We popped off the top cover and sprayed the visible part of the reed valves down with WD-40. When we put it back together we discovered that the valves on the intake and exhaust were both closed. It pulls a lot more vacuum now.
Gary
Bill Howatt
>I didn't realize at first that the plate between the head and the block existed and after fixing the top valves it still didn't work. Once I noticed the plate and got it off and cleaned up the set of valves underneath it things worked great. IIRC, I can pull about 26" or more of vacuum at the pump.
I'm not sure about the lubrication on the top end since there is no circulating freon anymore so I let it suck in a bit of oil everynow and then for good measure. It has an extra inlet port so this was easy to do.
Bill
Bill Turpin in WNC mountains
>Gary, remember that this compressor will pump some of it's oil out the discharge. There should be an oil sight glass on the crankcase. Keep the level at half full. I do not recognise your model number. Belt drive should use 300 SSU viscosity # 4-G refrigeration oil. Self contained motor comp should use 150 viscosity, #3-G oil. There should be a crankcase filler plug in the side. If you are turning wet wood you should install some kind of moisture trap before the suction inlet.
Bill
