High speed engraver
High speed engraver
High speed engraver
Tommy Holmes
>I am looking at buying a high speed engraver, 400,000 rpm. I know of Presto, Powercrafter and Turbocarver. Does anyone have any thoughts, sources, ideas and/or experience with any of these or other engravers I haven't seen? Any information is appreciated.
Re: High speed engraver
Darryl Hansen
>Check with Bin Pho. He has some comments bout some of the "engravers" on the market and why he likes the one he uses for demos. Something about the barings or something. www.wondersofwood.net
Darryl Hansen
>By the way Tommy Bin Pho uses NSK high speed drill...
Russ Babbitt Jr.
>I have have both the Foredom, I believe made by Powercrafter no longer offered by Foredom, and the NSK from Bin Pho. The NSK is a more expensive professional tool so you get what you pay for. If you plan on doing piercing like Bin your pieces must be turned thin. These tools do not have the torque to pierce thick wood unless you are very patient. The more you pay the better torque you can expect but may not notice unless you can compare the tools side by side. For occasional work the Powercrafter and others would be ok. For frequent work you should spend the money for the NSK.....
Tommy Holmes
>Thanks Darryl. I went to Bin Pho's website from your information and saw that he sells the NSK. That is recommendation enough.
Tommy Holmes
>Thanks Russ. I have read that these tools don't pierce thick wood well. I thought there might be a significant difference between the Powercrafter and NSK and that is what really brought up this question so your info was really helpful. I like the idea of getting better made tools if feasible.
DickAnderson
>Tommy:
I have both the Powercrafter and the NSK. Powercrafter requires oiling and the NSK is oilless. I prefer the NSK. High speed rotary carvers have very little torque, thus they don't tend to skate like you get with the Dremel, Foredom and other lower speed rotary carvers. I have only used my high speed carvers for piercing, which must be done on very thin wood, 1/16th to 1/8th inch.
Dick
Tommy Holmes
>I was hoping someone that had both the Powercrafter and the NSK would respond. Thanks for letting me know which you prefer.
