Source for m33x3.5 nuts for vac chucks
Dave Winters
>Anybody? Need to make some vacuum chucks. Or is there a better way??
Thanks again in advance..
Re: Source for m33x3.5 nuts for vac chucks
Don't overlook the simple.....
TDaniel
>The shop-vac powered plate from Vicmarc actually does a good job. It can be quickly installed or removed and it works.
Bill Howatt
>I make my drum chucks from 3/4 MDF with a piece of suitable diamater ABS pipe or a coupling expoxied into a groove. I found a tap (not same thread as yours)on ebay for making the threads in the MDF.
Bill
phil in NJ
>Lee Valley now sells a tap for m33 x 3.5... you could drill and tap your own wood (or mdf or HDPE or whatever) nuts...
Colin Spencer
>Dave
No problem buying them here in Spain for about $2 each but the shipping would be expensive (no flat rate here). If you do happen to be interested we could exchange some 33 x 3.5 for some 1� x 8 that I need as those do have to come from the US.
Colin Spencer
>oops that should have been 1� x 8 (must turn the light on in the morning) :)
Leppikallio
>That is standard metric size, M33x3.5. About 1.60$ each. However shipping would be around 10$ if weight of the package stays under 4.4lb (6, perhaps 7 nuts).
A4 grade (SS) nuts are little more expensive, about 16$ each.
Jerry from Lapel In.
>Try, thet have them listed. http://www.coburnmyers.com/index.html
Dave Winters
>Thanks, all. Coburn Meyers has a $50.00 minimum. I checked McMaster/Carr, no luck.
I do like the idea of a tap like Lee Valley has.
What else do you use for vac chucks?
Thanks again..
Re: Terry, I've looked for
Allen Neighbors
>this vacuum plate like yours, and can't find it.
Re: Source for m33x3.5 nuts for vac chucks *LINK*
Chuck Engstrom
>You might try Maryland Metrics, "Your one-stop METRIC hardware source." Web link below, phone 800-638-1830. Says they offer over 1,200,00 metric items. Don't know about price but I bet they have them.
Best --
Chuck Engstrom
Maryland Metric homepage
check with Greg Jensen or CS
TDaniel
Re: Found it, Thank you!!
Allen Neighbors
Steve Worcester
>You may want to make threaded MDF and glue more MDF on the front for the vac portion. Tap is about $30-$40. Or face plates.
http://www.turningwood.com/mdfchucks.htm (mdf chuck article)
Considering you may make up to 5 or so, either would not be too much of an investment.
Steve Worcester
www.turningwood.com
Re: check with Greg Jensen or CS
Dave L
>Terry:
How do you gt a hold of Greg Jensen?
here it is
TDaniel
>gnjensen@cox.net
