>Here is a photo of the knob job. This is the first time I've tried to make identical turnings. 18 knobs more or less the same. I used a stick with nails in it to mark the transitions. To me they all look different, but hey that's what makes them craft. It took most of the day to make all 18 with only 4 mistakes (catches etc) and 2 trial runs. I actually charged enough to make it all worthwhile.
>Nice work, Dave. Production work can be pretty satisfying, I like it. They all look alike to me but I know how we are all too critical of our own work and you see the variances. When they are attached, they will look perfect.
How did you mount them on your lathe? A knob this style was the first thing I ever turned. I cut the head off a screw, and chucked it up in the drill press, and screwed a blank on. Used a bench chisel to turn it. Now, I use a tapered (screw end matches the size of the base of the knob) wood mandrel with a screw centered in it, and screw the block on (predrilled hole, and wax the screw).
>Yeah, it was fun figuring out the production steps for efficiency. I did it pretty much how you said. Made a wood mandrel mounted in my chuck (just because it was easy), drilled a hole for a screw and ran the screw through the back. The end of the mandrel was turned to the diameter of the base of the knob. Then cut a bunch of short square blocks of wood for the knobs and drilled a pilot hole in one end.
The actual turning process when like this: Screw a block on the mandrel, rough to a cylinder, use the pointy end of calipers to scribe a circle of the max diameter on the face, finish rough to max diameter, use stick with nails to mark transitions, turn the knobby part, use another stick with nails set to the different depths to finish the turning, burn a line on the knob, then sand and unscrew it. All with the lathe running.
My actual turning time was closer to 4 hours, about 13 minutes per.
>These are nice, Dave, and, as Ruth pointed out, they will look even better on their intended target.
I made a batch of 8 Cherry drawer pulls like these for a custom furniture job last summer. I agonized over the tiny differences between them, but these could only be seen when they were side-by-side, and they looked great on the chest of drawers.
My customer wanted to attach them with #8 or #10 threaded inserts epoxied into the knobs, (I don't remember the exact size), so my first step was to make a mandrel with the desired screw sticking out, then I drilled the stock, inserted and epoxied the inserts, then screwed each down onto the mandrel, turned and polished. Once I got set up, they went pretty quickly.
