Mounting for end grain turning
Thad Parker
>I'm going to attempt an end-grain bowl from that mystery wood (yew...or arizona cypress...or some cedar species?) and am curious what the preferred method is for mounting this.
I'm guessing compression from the chuck onto a tennon to avoid splitting the wood, but what about before I reverse it? Will screws hold it sufficiently to the faceplate to turn the tennon? Are there any glue options for endgrain?
What's your method? What have you done that did not work?
~ Thad
Re: Mounting for end grain turning
Brad Vietje
Brad Vietje
>Thad,
I turn between centers in spindle orientation, shape the outside of the bowl and a tenon, and grip in the largest chuck jaws that will do. After hollowing, there are a number of options for reverse turning, though I usually go back to turning between centers with some turned plug snug in the opening.
Another time-saver is to make TWO tenons while you're on your first mounting, and use the one at the opening to hollow the eventual foot so you don't have to remove so much later. Then this vestigial tenon gets turned away before hollowing when you flip the thing.
Safe spinning,
Brad Vietje
Newbury, VT
Walt Drummond - Middlesex, NJ
>I like that idea of 2 tenons. Learn something every day. Thanks Brad
Fog Tanner
>Depends on the size of the bowl. I make some small endgrain bowls up to around 6". I turn between centers, putting a tennon on one end. Chuck up on the tennon and then hollow the inside. Then turn the outside as close to what will be the foot as possible. Either use a jam chuck or a set of cole jaws to finish up the foot area. Depending on how much wood you want to waste you can turn the whole of the outside and then just have the bottom of the foot.
I also watched Andre Martel do an engrain vase. He turned a cylinder with a tennon. Then reversed it and turned the bottom, alowing a rebate for the chuck jaws. He then turned a secondary tennon larger than the eventual foot. Once this was done he reversed it and turned the outside and then hollowed it. After the hollowing, he thinned the outside some more. Once he was happy with the outside, he chucked up using the rebate and turned off the tennon to the finished size. This left him with a vase with the bottom finished and ready for finishing.
Steven Smith
>I put the blank between centers with the top toward the tail stock. Turn the top flat to receive a face plate. Remount using the face plate and shape the outside leaving a tenon for the foot just the right size to allow your chuck jaws to hold tight when they are completely closed. This way there will not be any jaw marks or if there is it will be a ring right around the base of the tenon. Finish the outside complete with your signature. Remove the face plate and carefully remount using the tenon (bowl foot) in your chuck. If you are not comfortable that the chuck is holding tight enough put a wrap of tape on the tenon. Hollow the inside and finish. After you take it out of the chuck you may have to touch up the finish on the tenon.
Jimiles-Charlotte, NC
>Thad: my method would to screw a faceplate to what will be the top of the bowl. Turn the bottom (and outside if you wish) at this stage. You can then turn the blank around and turn the inside. You will turn away the screw holes as you do the inside. A foot for a chuck will work fine or you asked about glue block. I mostly will flatten the bottom of the foot for a waste block of Pine 2x4 or 2 x 6 - it will hold fine on end grain - give it 2 days drying time for yellow glue. Before you remove the faceplate, put it back on the lathe and mark center of waste block for faceplate or turn foot for chuck
Thad Parker
>Any risk of the screws tearing out of the endgrain?
Bill Howatt
>Based on my experience, yes. However, it depends on the wood, a good, dense hardwood will actually hold quite well - softwoods are more difficult. I use sheet metal screws typically in the #12-#14 size. For endgrain I wouldn't use anything under 1-1/2" long however if your faceplate lets you put in lots of screws you could get away with shorter.
Bill
Re: Mounting for end grain turning *LINK*
Darrell Feltmate
>I mount between centers and rough to shape leaving a section for a face plate. When I screw on the face plate I slant the screws a bit for a better grip and away we go. If I want to use every last bit of wood I either super glue on a waste block or turn away the screw holes in the design.
Around the Woods
