>I am a new turner and have a Jet 1236 lathe. This lathe can swivel the head 90 degrees and , with the use of a banjo, allow me to work on the interior of the bowl without leaning over the lathe bed.
Should I learn to turn the interiors in the conventional position (inboard over the lathe bed) or should I learn to turn them outboard?
>by all means turn them with the head swiveled. It's much easier on you. Some lathes aren't as rigid when turned like this and it causes vibration. Some of them use a tool rest extension which can also cause vibration. If you have these problems then go back to between centers. That's part of why I went with the Powermatic 3520. I could slide the headstock down to the end and stand upright while hollowing bowls.
Another advantage of hollowing this way is that you can control the gouge with your hip which allows you to make a much more controlled cut. When you have your arm hanging way out over the bed it's hard to get a really smooth curve on the inside.
>I also use a 1236. What I find useful is to turn the head just a little ways, not even to the first detent, and lock it down. This allows better access to the inside and I can still use the 12� tool rest without the extension. In my case I don�t have the extension, but others here have mentioned safety concerns inherent in them. I only leave it lined up with the bed if I�m using a work steady for long vases.
Another concern that can benefit from pivoting the head is that you can reach the off switch more easily. Of course, you could rewire the off switch to a more convenient location.
>I agree. The outboard turning toolrest extension is best suited to use as a canoe anchor, a trolling weight for huge fish, or a blunt instrument to thwart a dangerous assailant. It is a half-assed design on its very best day, and an exceedingly dangerous piece of junk on every other day. I advise you to never use it -- search the archives for my numerous rants about this.....
My take is that the 1236 works well within its limits(I actually own one...) When you need turn a few lighter pieces a little over 12", it will work fine. If you make a habit of it, especially with heavy, wet wood, you'll do better to buy a bigger lathe. The bearings, the toolrest banjo, the tailstock, and all the other parts aren't up to the pounding that regular large-diameter work dishes out, IMHO. Been there -- done that. Bought the PM3520-B. ;~)
>I have the Jet 1242, What I like to do is slide the headstock towards the end of the lathe after removing the tail stock. I leave just enough room between the headstock and the end of the ways for the banjo and a little for adjustment. The I stand at the end of the lathe and hollow there. No outboard stress on the lathe, banjo, or tool rest and I can reach into the bowl very easily.
Of course, this supposes that you have room at the end of the lathe.
>I wore out two of those lathes. One thing I added which made a VAST improvement was a Oneway 1224 banjo & toolrest. They cost more than the value of the lathe itself, but made a HUGE difference.
