Maple gone bad
Maple gone bad
Maple gone bad
John in MD
>Finally got around to cutting up a section of trunk from a Silver maple my neighbor took down last year. I liberated a couple of larger trunk sections, hoping to use them for lathe practice.
Looks like maybe I waited too long to cut the logs up into turning blanks. The wood is still solid, but has all this discoloration and streaking. I guess it went bad (like that bologna I found in the fridge).
Too bad. Hate to see good wood go bad like this. I was hoping to get a nice platter or maybe a bowl out of some of the larger trunk sections...
Seriously, I just wanted to gloat about the spalting I found when I finally split one of these rounds. Can't wait to try to make something pretty out of it.
Any suggestions for finishes?
Thanks.
-John-
Re: Maple gone bad
Re: Maple gone bad
Bart Rhoads
>One thing to keep in mind when you select a finish is that any oil finishes will have a tendency to darken the wood some what where as your laquers and polyeurthanes will darken some but not near as much. The water base polys are more clear than any I have used.
Re: Maple gone bad
Re: Maple gone bad
Barry Turner
>Yeah, that stuff is definitely bad! Just stack it out by the street and we will properly dispose of it for you.
Re: Maple gone bad
Steve Kubien
Re: Maple gone bad
Steve Kubien
>Too bad about the lost wood. Really, my heart bleeds for you. I have only done one piece in spalted maple and I used lacquer on it. It is probably my favourite finishing job I have done.
FWIW
Steve Kubien
Ajax, Ontario
Re: Maple gone bad
Re: Maple gone bad
George Van
>John, I have had good luck using thinned 50/50 lacquer and thinner for a sealer coat after sanding. I then wipe on as many coats of oil/varnish coats as i deem necessary for the finish sheen required.
Re: Maple gone bad
Thanks for the replies
John in MD
>Thanks all -
I will probably try the laquer/thinner mix as a sealant, followed by unthinned laquer.
Hope to be able to get some lathe time in the next 2 weeks, so I'll post a photo for critique later this month.
Many thanks for the replies, and finishing recommendations.
-JOhn-
Re: Maple gone bad
Re: Maple gone bad *LINK*
Darrell Feltmate
>Nice spalt. I was asked what we do to get spalted maple in Nova Scotia and my reply was to get too busy to turn :-) I like to use a thinned varnish on spalted wood and lots of other timber as well. It soaks in well the first couple of times and really pops the spalt lines. I do not really measure it, just thin maybe 20 percent or so.
Around the Woods
