Grinder question...
Grinder question...
Grinder question...
DWR
>... I am in the market for a new grinder... upgrading to an 8" and a Wolverine system... (20 years of freehand grinding and I am ready to do a "jig").
My question is: What width wheel do you recommend? I have always used 3/4" wheels but have been giving serious thought to moving to 1" wide wheels. Selection of 8" grinders with 1" wide wheels is more limited but still have some good choices.
Those of you that use 3/4" and a grinding jig, do you feel your results are good or do you wish you had 1" wide wheels?
Thanks!
Re: Grinder question...
Doug Thompson near Cleveland
>A 1 inch wide wheel is common with a 8 inch grinder. Don't mess around with a 3/4 inch wheel. If you want to talk about about wheels say something.
DickAnderson
>1725 rpm grinder with 8-inch Norton SC 46 grit wheel is my choice. The other wheel is my original 80-grit white.
>I have an 8" slow speed grinder. I put a 1" wheel on one side and 3/4" on the other. There really isn't much difference. It's probably easier to grind my big skew on the big wheel. I like the 1" and if your starting from scratch I would consider buying one but if you already have 3/4" I wouldn't change. There isn't that much difference.
robert davis
>the 8" slow woodcraft grinder is a good choice for many
Slow speed grinder question... follow-up
DWR
>I was looking at the slow speed generic at Woodcraft. Then Oneway's Wolverine instructions at Woodcraft said that they recommend the high speed grinder due to the higher surface speed necessary for HHS... complete with their version of statistics to "prove" their point.
I have always done freehand on my HSS, using a 20 year old 6" high-speed grinder... but will be getting a new set of tools... (Doug...) after 20 years and figured I would replace the grinder and get an 8" unit.
Dave
Keith Tompkins
keith tompkins
>Dave, I use an 8" wheel, 1" width. That's my wheel size of choice; I've used almost every conceivable setup and like that the best. The extra width is useful when using a side-grind jig. I've never understood the current trend to low speed or variable speed grinders; I see no advantage over a 3600 rpm grinder, and several disadvantages.
Say something...?
DWR
>... anything in particular?
Well, I like 'em round... the rounder the better!
Dave... (sorry I missed your call last night... had a business meeting.)
Keith, I agree...
DWR
>... with you on the speed. The 1" width also makes a lot of sense, especially when doing freehand work. I always had some interesting moments when trying to roll a 5/8" gouge and stay on the wheel... that extra 1/4" would have been real handy!
Going to the Wolverine for a more consistent grind, not to mention more efficient when re-dressing the grind since you don't have to worry about working out the facets, seemed to remove some of the wheel width concerns... but the extra width just seems to make more sense regardless...
Thanks,
Dave
Gary in Zirconia, NC
>Woodcraft has the 8" slow speed on sale right now for $75. with white wheels.
TDaniel
>I prefer the 1" wide wheels and the lower rpm. The lower rpm is safer, especially if a wheel were to blow up but mainly it is a balance thing....the higher the rpm the more important the quality of the grinder should be. An unbalanced wheel or a wheel that isn't 90 degrees to the shaft will give you problems. The "bargain" grinders usually have stamped "washer" holding the wheel to the shaft and they are not true; the better grinders have machined hubs that keep the wheel perfectly 90 degrees to the shaft. One-way has a balancing kit which includes machined hubs ($50) and this kit will fix the "bargain" grinders.....or you can spend the $50 and get a better grinder to begin with and then you will not need the balancing kit. I would recommend a Delta 8" l750 rpm grinder....not a variable speed or if your checkbook can stand it,a Baldor. You are going to spend a few bucks but you should never have to buy a grinder again. In either case, make certain that you do not set up your jig so that the tool end is near the center of the wheel as disastrous things can happen when a tool is pinned between the wheel and the jig near the point of tangency.
Re: Keith, I agree...
Jorge Castaneda
>DWR
as long as you are considering a jig, take a look at the Kelton, I think it may be better.
Re: Say something...?
>I like them round too... but a Norton 3X is a good wheel that's priced right and that's the direction I'd look for round wheels. I did pick up some 3,000 grit wheels from ebay that I'm going to try out one day.
Peter Teubel
>I got a couple of those 3000 grit wheel on eBay too. They are so light, they almost seem to be made of foam. I'm planning on using them for my carving tools...mounted on a mandrel turning slow.
Re: BVariable speed
Russ Fairfield
>All grinders are variable speed. If the grinder is spinning too fast and removeing too much steel too fast from a small tool, just shut the motor off, and let it coast down to a more teasonable speed for the tool being ground.
>Peter, for the price it's worth a try. I plan to use them like a Tormek, slow speed in a water bath or use the side of the wheel to hone.
Let me know how they work.
Barbara Gill, Remlik VA
>The Oneway Balancing System balances the wheels.
True, but......
TDaniel
>more importantly the One-way balancing systems includes machined hubs which hold the wheel in perfect alignment. The vibration can be caused by wheels that are not balanced or by wheels that do not run true. If your wheels are not running true they may not be out of balance until the first time you dress the wheels, especially if you dress the sides of the wheels any at all. DAMHIKT
Ken Grunke from SW WI
>A wider wheel adds a bit more of a safety margin when using an Ellsworth or Wolveringe jig to grind a gouge for swept-back wings. I sometimes have a tendency to slip off the edge when swinging the jig around.
DWR
>Ken,
That's one of my problems with free-handing on my 3/4" wheels and why I will be going to the 1". Nice to know that, even with a jig, you need to stay alert to skipping off the edge...;)
Dave
Re: Grinder question... *LINK*
Darrell Feltmate
>I am happy with a 3/4" wide 6" wheel on a high speed grinder and a home made jig. Quick and reliable. I see no harm in an 8" wheel, a slow grinder or a commercial jig though :-)
Sharpening
Darrell... I looked at your...
DWR
>... sharpening section over the weekend (while searching threads on grinder wheels) and decided to draw up some plans with my CAD program. Took the calipers and measured the clearances on the 6" grinder and I think I can squeeze a 1" wheel into the housings.
So, I am going to make my own grinding jigs, per your design with a couple of modifications, and use the Wolverine money for some good Norton 6 x 1 x .5 wheels.
I will e-mail the drawings to you for your use as you see fit.
Dave
