Grizzly lathe
Randy Szkola
>I am looking at buying a grizzly 1495 lathe . Anyone have any experience with these ? good and bad
Thanks
Randy
Grizzly lathe
Randy Szkola
Thanks
Randy
Re: Grizzly lathe
>That's a lathe I have trouble recommending. First, it has an odd size spindle thread. It's 1" x12. It will be hard to find faceplates and chuck adaptors for that thread. I think the disc sander on the outboard size is a waste and would get in the way more than it is useful. I've never been a fan of gap beds. They also get in the way more than they are useful but it depends on what you turn as to whether you would use the gap.
I would look at the 0632 or the 0462. I've seen the 0632 and it looks and feels like an excellent lathe. I don't know anything about the 0462 but the specs and design look like they would work.
Re: Grizzly lathe
Don in Central Illinois
Re: Grizzly lathe
>Sorry about that. I hit the wrong button.
Re: Grizzly lathe
Andy DiPietro
>I have the G1495 lathe. It is good for making spindles, pencrafting and small bowls only. The slow speed setting is too fast at 500rpm and the 3/4hp motor is too small. Model G0456 has a min speed of 500rpm at 2 hp which can be a dangerous combination. The G0632 Looks like a copy of the Jet 1642 which may be worth considering. It may be worth paying a little more for the Jet 1642 since it has a real good track record.
I upgraded to the Powermatic 3520B for making hollow forms and large bowls and I only use the G1495 for the occasional pen kit.
Andy DiPietro
Re: Grizzly lathe
Rick Davenport
>I own a Grizzly bandsaw and drill press, and I like them.
But I believe you will be happier in the long run by spending a bit more on your lathe.
There are lots of good ones out there (Jet and Nova are the first that come to my mind).
R
Re: Grizzly lathe
Allen Neighbors
>Randy, I go along with John on this one. That odd-sized spindle is going to give you headaches all the time you own it.
Also, if you decide to buy a different Grizzly, talk to a human, personally, and get them to agree that if you discover the headstock and tailstock don't line up, that they'll make it right.
I have a Grizzly 5979. I had to grind like a dawg to get it lined up, and then the 1/2 hp motor wouldn't even spin when I applied my first 1/2" bowl gouge to a piece of Bois d'Arc. The slow speeds are too fast for unbalanced wood, also.
If you use a scroll chuck, the gap bed is worthless to you, and gets in the way of using some attachments... like a bowl steady, or a steady rest.
Don't want to rain on your parade... and I use my Old Griz quite often for lids, small pieces, sanding bottoms, etc., and I like it. It just isn't conducive to extended turning sessions or variety.
my .02, for free.
Allen
