Free-Standing Tool Rest
Rob Hix - King George, VA
>Hey all,
I was wondering if I could get some help coming up with ideas for a free-standing tool rest. Right now I am turning on an old Shopsmith and I am wanting to do some Shaker style chairs. In order to turn the back legs/back posts I will need to extend the lathe bed. If the lathe bed gets extended, then I cannot use the on-board tool rest.
Does anyone have any suggestions, plans, pictures, etc. of free-standing tool rests that work well.
I would also welcome any suggestions, plans, pictures, etc of extending the length capacity of a Shopsmith lathe. I have several ideas, but the more the better.
Thanks in advnace,
Rob Hix
Re: Free-Standing Tool Rest
Re: Rob- a free-standing tool rest is a.....
Jamie Donaldson
>... real safety hazard when not attached to the lathe to prevent movement into the spinning wood. Sounds like you have an excuse for purchase of a real lathe!
>Jamie,
I may have a reason to buy a real lathe, but I do not have the resources right now. In my mind I have a way to extend the bed of the Shopamith for the lathe function. After all, for chair legs I do not need much swing. I may also be able to fix the extension with a tool rest on it.
Since the current tool rest will cover more than half the length of the leg, I could also turn the lower (or upper) portion of the leg and then turn the leg end for end and do the other end.
I have options, I am just trying to feel out what the good ones vs. the bad ones are.
Thanks for the input,
Rob
Russ Fairfield
>Furniture parts are easier to turn if the tool rest is the full length of the wood in the lathe. Wood is an acceptable way to make them.
I make my long tool rests from Hard Maple. Wood is better than a piece of steel because the steel vibrates. I use 2 tool posts, and sometimes 3, that I bought from Woodcraft who sells them for their aftermarket tool rests. I recently invested in a 2nd banjo for the lathe, but for years the 2nd banjo was a glue-up of Hard Maple with a slot over the lathe bed for a clamp-bolt, and a hole for the tool rest post that was secured with a large brass sheetmetal screw. I still use it when I need 3 banjos on a long tool rest.
As for entending the ShopSmith. Why? There is no rule that says the headstock and tailstock have to be a part of the same machine. They can be across the room from each other.
You can move the tailstock off the lathe by clamping it to a separate table. A workbench works very well. Stack concrete blocks on it to keep it from moving. Or, you can build a dedicated stand for it. Clamp a piece of hardwood between them for a tool rest, and you can turn anything of any length. A WorkMate makes a good support for a center tool rest and a steady rest that can be fabricated from construction 2x4's. The WorkMate isn't sturdy enough to support the tailstock for a very long span, but it can work very well for a short distance off the lathe.
It may not look pretty, but it works. Above all, be safe, and be careful.
I haven't seen a shopSmith in years, but if I remember right, the tailstock is an integral part of the machine and cannot be removed. I think you should be in the market for a new lathe that is better suited to turning long furniture pieces than a ShopSmith that can be configured to do everything, but does nothing well.
RevDoug
>You could use a shaker idea. How about making the legs in 2 parts? Design them with some kind of feature at the joint and then turn a tenon on one of the halves and a socket on the other half. They should fit together pretty closely. Glue together and clamp over night. It's done all the time.
Turn 'em round,
Curly Smith
>You might try asking in the ShopSmith Users Group. One idea for extending the bed is:
ssug.org :: View topic - extending lathe bed:
Re: Free-Standing Tool Rest *LINK*
Gil Jones on Lake Seminole GA
>Check out this AAW link to see a Japanese freestanding toolrest. The idea may seem dangerous, but I expect that it is only so if not used properly. It looks pretty sturdy to me. There may be other sites that show the traditional Japanese lathe toolrests, but this is all I remember for now.
Gil
http://www.woodturner.org/resources/eog/japan_exch_2004
>Russ,
Actually, the only thing I use the Shopsmith for is the lathe and the bandsaw. Actually I haven't got the bandsaw fixed up good enough to use it yet.
The lathe has done everything I have asked it to do except for this. I really do not want to invest in another lathe at this point in time as I am not sure that this will be something I want to do often.
As to extending the bed, I am first going to try it with the extension attached to the Shopsmith to make everything easier. I think I have a pretty good extension design that will work.
>Russ,
Sorry, I hit post before I meant to. I was actually thinking of building a really long tool rest. A few weeks ago I tried turning a couple of rolling pins for LOML and a realized really quick that turning a 24" object with a 6" tool rest was a pain in the tail stock.
I would really like to see a couple of pictures of your wooden tool rest if you could find a couple. I need some ideas there too.
Thanks again,
Rob Hix
Curly Smith
>For the tailstock extension:
If you pull the tailstock out you should have two sets of two holes that line up vertically. It seems to me that you could attach a 4x4 to the lathe with threaded rod through the holes and held in place on the top and bottom with wood blocks and nuts. If you cut dadoes in the block you could extend the lathe with 2-2x6's whatever length you desire and then connect, again via dadoes, another 4x4 with holes drilled to accept the tailstock. You should be able to make a clamp to hold the tailstock by drilling a hole in a scrap the same size as your tailstock pipe, drill a hole an inch or so away and perpendicular to the tailstock hole for a carriage bolt, cut a kerf from the end with the hole to the center and you've got a compression clamp (probably not a good description but hopefully you get the idea). Make two, slip them over the end of the tailstock below the 4x4 crosspiece, tighten the carriage bolts and the tailstock won't go anywhere. Attach legs with a shelf for a bag of cement and you should be in good shape.
For the toolrest:
Stealing the idea about wood tool rests, how about a closet rod tool rest? Take a couple of pieces of 2x6, rout slots in the bottom face a couple of inches long a few inches from the end. Drill holes in the top edge to accept the closet rod (maybe drill a 1 1/2" hole centered 3/4" from the edge and attach a 1 1/2" rod with glue and screws?). Drill holes in one 2x6 way for carriage bolts. Attach your full-length wood tool rest with wing nuts or star knobs. With the slots your tool post is vertically adjustable, use spacer blocks between the "posts" and the "ways" for horizontal adjustment.
>Rob Some good ideas. I've built a free standing tool rest and it takes a lot of skill to use. It wants to pull into the wood unless you have the gouge rotated just right and the cut is pulling in the right direction. I'll try to post a photo of mine. It needs work, especially more weight at the bottom.
Russ has the right idea for chair parts. Long tool rests. Easily made out of hardwood. I don't think closet rod is good enough because it's fairly soft but it would work for a few before it gets dented up.
I can't remember if the tubes of the shopsmith extend through the attachment points but if they do then I would turn a big dowel to fit into them and stick out several inches. Then attach a 2x8 to these and extend it out as far as you need. Drill some big holes to hold the tailstock and your there. You would probably need to build up a spacer block to get the tailstock to the right height and I would put some sort of adjustable support under the tailstock assembly to stabilize it. Then it would be fairly simple to attach another block to support one end of the long tool rest.
>Curly and John,
Thanks for more ideas in the grey matter. What I had thought up was to build two narrow torsion boxes. To the shorter one I would attach some wooden posts to fit down into the hole where the tailstock goes now. On the other end of this torsion box fix a wooden clamp to grab the upper two parallel bars on the ShopSmith. The other (longer) torsion box would attach to the first on the outside of the ShopSmith with bolts. This torsion box would be sized to provide the extra length I need. I would simply drill holes in the end of this torsion box and provide some bolts to hold it in place.
I was thinking the torsion box because it would be easy and cheap to build and it resist flexing. Of course, so would a 4x4 or some massive piece of lumber like that.
As for the tool rest, I just need to get an idea of what shape it needs to be where the lathe tool is resting. I can probably figure something out for the rest of it.
Thanks again,
Rob Hix
Thanks again,
Rob Hix
>Rob I think the torsion box is a good idea. The tool rest is simple. Take a piece of hardwood and simply cut an angle on the top. I've seen antique lathes with tool rest that were round on top (think roundover bit on a router), flat on top and beveled on top so apparently it isn't that critical. Personally I like to have the tool supported close to the work so I cut about 45 degrees on mine and leave a flat area about 3/16 to 1/4" to give the narrow part strength.
As far as thickness goes it depends on how long your tool rest is and how thick the wood is. I used a 1x3 piece of oak when I did the long lamp. It was a little wobbly in the middle but I took light cuts and got away with it.
Curly Smith
>I wonder if we're not making this too complicated.
The bed on the Shopsmith isn't more than 12" wide so I'm starting to wonder what would be wrong with a simple piece of 3/4" plywood for the extension...
I'd cut 2 2x4's a couple of inches longer than the width of the rails, clamp them together and cut 2" holes (I think that's the diameter of the bars) "between" them to get 1/2 hole on each face, with the holes spaced to match the rail width. Then glue and screw one 2x4 to the plywood and clamp the plywood extension to the top SS rails using the other 2x4 and some carriage bolts. At the other end I'd just beef up the tailstock location with a piece of 2x4 (or 2x6), drill the holes and clamp the tailstock in place with compression clamps. Add some legs (or a leg) and maybe some weight to dampen vibration, drill some holes for your tool rest and you're done.
>That's so crazy it just might work. It will be at least a couple of weeks (and probably a couple of months) until I get around to doing this, but this might be a workable solution.
Thanks for all the great idea,
Rob Hix
Re: BT/DT
Mike Hamilton
>I needed to extend my shopsmith ages ago to make a replacement leg for a rocker. Much like Curly describes above. The 'bed' of my extension was plywood reinforced where the holes were drilled. I put legs under and assumed the blank under compression would make everything just fine. Even with legs, it wanted to bend the bed downward. Cured this by placing the tailstock end of the whole works against the garage wall for reinforcement. Happy to only have one leg to turn.
Tool rest was full length from wood.
Good luck and be careful,
Mike Hamilton
Plainfield, IN
Heck, Jamie, I turned at least..
Don henthorn
>40 SYP stools with seats about 15" X 1 1/2" outboard on my old Blount lathe using a free-standing tool rest and no problems. Well, except for the blank that flew apart because it had a split I couldn't see. I made the rest by welding a four inch pipe to a truck wheel and then fabricating a tool rest atop that. It was steady as a rock.
Re: Don- aside from tripping over ..
Jamie Donaldson
>.the truck wheel all the time, that rig was probably heavy enough to not move easily. The safety problem with flimsy improvised rests occurs when they tip into the spinning wood because they're not attached to the lathe.
You will need a kitchen broom...
Jerry Hall
>I had an old 1956 ER Shopsmith on a wood stand. I had to turn large tenons on 8 foot long lodgepole pine poles for a cabin full of furniture, couches, beds, chairs, footstools all basically the same design with round mortises and tenons. I had never done any turning and couldn't figure out how to do it. Days went by. Considered elaborate router jigs. Finally I stood with the tail stock in my hand and my butt leaning against the vise on my very heavy bench. Eureka! measured the height of the spindle. Matched the tailstock in the vise. Used Jorgenson clamps to tie the whole thing together with 2x6's. Sighted down the axis as best I could. Adjusted. Adjusted. Set the speed on slow (not very slow tho) mounted the first eight foot by 5 inch dia. pole. Was scared to turn it on, so I got the kitchen broom and reached with it from a safe distance to turn on the shopsmith toggle switch. Pretty wobbly. Shopsmith walked. Did some more alligning. It worked! Reversed the pole to do each end so I had no tool rest issue. Made 3 king size beds, two couches and lots of other stuff. Also had lots of catches. Never properly sharpened the old carbon Sears tools. Didn't have a clue how. Used a bench stone as best I could. Scraped my way thru somehow. Didn't do any turning again for 20 years! I laugh now. Powermatic I have now would have worked better I am pretty sure.
As Russ says, you can do it with a low tech solution. I have some pictures somewhere, and if I can find them I will post one.
Japanese woodturning
wilbur
>I saw a video and read a chapter in a book about Japanese woodturning. One key difference between Japanese woodturners and Western-style woodturners is that Japanese woodturners do most of their work with scraping tools below the center line, around where most Western-style woodturners would do their on lathe sanding. I guess that if that is your point of contact, the issues of a freestanding tool rest being pulled into the work don't apply.
Bill Crommett
>Rob: I have an older Shopsmith (model B) which I have used for turning stairway railings in the past. To do the extention, I carfully measered the hight of the dead center and bolted (lagscrewed) the entire end to the wall and then carefully blocked the machine so it couldn't move. The steady rest was improvised from an old bulldozer traction gear that I used for an extention roller when ripping long pieces of lumber.
