>I am a relatively new turner and enjoy turning bowls with mild to moderate narrowing of the opening, not the "extreme" hollow form work with a tiny opening. I am to improve the smoothness (before sanding) of the underside of the lip and avoid "dig ins".
I would appreciate any comments and suggestions re: the newer tools (Hunter, Rolly Munro, Supercut, Hamlet, Bosch, others).
>I like my Don Pencil Scorpion set up. Don is a sponsor here at WoodCentral. These were the first hollowing tools I used and I have been pretty successful with then right off the bat and gained a lot of confidence in trying deep hollowing.
>I have 5 Don Pencil sets so that I don't have to stop and change bits. They give me the flexibility to make flat topped natural edge hollow forms with rather small openings and high sides. I do have a captured rig too but I seldom use it.
>Bill I'll make a suggestion that doesn't require a new tool. Take some scrap wood and turn the outside shape you want. Then drill a couple of large holes in the top in the area where you are having trouble. Then when you are hollowing this area you can actually see the tool through the holes as they spin by. don't do this on thin stuff because you don't want the wood blowing up. What your trying to do is learn the "feel" of the tool and the cut. This method lets you see the tool as well. It requires spinning the wood fairly fast (but not dangerously so) and taking light cuts. I find this really helps in learning to turn smooth because you can stop the lathe and reach in a feel the lumps. Then you can go in with the tool and try to smooth them out.
If you don't already own a tool that will reach these areas then you need to look at the suggestions above. After you purchase one then try this method. You will be surprised at how this speeds up the learning curve.
>I agree with John, as per usual, and usually use the perforation method (shamelessly stolen from Robert Chapman) to teach hollow form turning. Regarding the Don Pencil tools mentioned earlier, I have never used them, though everyone seems to like them. I use both home-made tools and some commercial, hand-held tools from David Ellsworth, Michael Hosaluk, and John Jordan. Usually I finish turn this undercut area with a home-made tool made from a 5/16 Allen wrench that I basically use only for this one task. Sometimes I also use a Sorby 3/8" shaft goose neck hollowing tool with the 3/8" bullet tip for smoothing.
On the technical side, I finish turn this area while there is a little thickness down lower for good support. I use relatively high speeds for this -- depends on how sound the wood is, and the size -- and very light, shaving cuts. I keep the cutting tip above, never below, center, and usually lower the tool rest and the handle, so I can "reach up" inside the vessel with a good dose of CCW rotation (tip still at or above center) for a shearing cut. For finish cuts I do not prefer torque-arrested tools that don't allow for CCW rotation -- doing this with proper hand-held technique is like petting a baby bird with a feather -- very light touch !
>I haven't mastered hollowing yet, except some small ones done with a spindle gouge, but I would also suggest that next time you are turning a bowl, before you get near that final pass on the inside, try using your hollowing tools. It will give you a very clear picture of what is happening inside when you move outside. Might want to put some tape markers on the toolrest to restrict your side to side movement similar to a small opening.
The Jordan tools and a few others use a 3/16" piece of HSS drill blank or key stock as a bit. If you can drill and tap steel rod, you can create an number of home made tools by using steel rod with a 3/16" hole for the bit and a tapped hole perpendicular to it to insert a set screw. The Hunter bit is offered in a size compatible with a 3/16" hole, but it seems pricey at about $70 for one carbide cutter and a very small piece of steel. I would imagine making one would be less costly.
A lot of guys in our group have been quite enthusiastic about the Jamieson hollowing system, or one featuring a captured D-handle. John Lea makes one as do several others and there are plans around for making one yourself.
Chris Wright has a great description of hollowing on his web page. I have the main image from his description as my wallpaper on my computer. The link to the article is below.
-Craig
P.S. Let me know when you master it and then you can tell me how.
>Brad Fantastic description of how you finish the inside of a vessel. My good friend John Roberts used to tell people it was like pulling your fingernail across the back of your hand and barely feeling it. I like your description better.
>Thanks for everyone's suggestions. Very helpful. When I go to work tomorrow in my real life at a children's hospital I'll remember the feather approach.
