Chuck Wobble redux
Philip Duffy
>So, to bring a long and painful story to a pleasant close - -the mounting adapter (Nut) was the culprit. When I switched the nuts to see if the wobble followed the nut, it did! Thanks to the great support from Ray Deyo at Woodcraft, Richmond, the problem is now solved. Also, tech support chief, Tim, gave his support to the problem as well. Thanks to you all.
--- Goes to show you a guy should check his wobble when it wobbles! phil
