Vacuum pump adapter
Vacuum pump adapter
Dave Shombert
Vacuum pump adapter
Dave Shombert
>I've been attempting to rig a vacuum chuck setup, including making my own rotating vacuum adapter. Yeah, I now, Oneway makes one for about a hundred bucks. Holdfast makes one that's even cheaper. I wanna make my own, blast it, incorporated into a homemade handwheel (I have a General 26020) with a quick-disconnect air hose fitting. Of course, this requires a bearing. I made one with a shielded bearing, but it leaked and I'm pretty sure it was through the bearing. Then a friend suggested a 2RS bearing (rubber shields). I found some on eBay and asked the seller if he knew whether they'd hold vacuum or not - answer, NO!. One of his few negative feedbacks was from someone who tried to use one of his bearings in exactly that application.
I recall that David Ellsworth had such a thing when I was at his place a few years ago. I emailed him about it but haven't heard back. Has anyone here made their own adapter? How did you deal with this problem? Thanks,
Dave Shombert
Elkins, WV
Re: Vacuum pump adapter
Darryl Hansen
>Dave try Boca Bearings in florida as I remember and tell them what you're after they may be able to help. The Nova adapter ($30) fits into a recess in the handwheel. The recess is larger than the hole through the wheel so the bearing inner ring is where the vecuum is drawn. You might be able to seal around the face of the bearing with silicon or some such. I draw over 27" with that set up. Another source of leakage I have found is around the face plate threads. Darryl
Don Evans
>Dave;
This may help in your quest.
shielded bearings have silver metal covering the race (ball assy)
SEALED bearings have a black material that is slightly flexible.
DOUBLE SEALED has this same material on both sides of the bearing.
What you want is the double sealed bearing. Infact it is a good idea to use that type bearing for any application as they are on slightly more costly that their equal in shielded version. They keep the grease inside better and dirt or contamination out. They will pay for themselves because they last longer.
Don
Bill Howatt
>No personal experience with this but I have read several posts mentioning that a air-hose connector is made to seal when under pressure and may not seal totally in a vacuum application. Make sure that isn't a problem as well.
I have a General 26020 as well. I opted for the Oneway system so I could get on with it and a homemade rotating interface seemed to be an additional leakage source in many cases.
Good luck,
Bill
Been ther, done that...
Peter Teubel
>I've made DOZENS of vacuum adapters for folks and even teach a class on it. The bearing I use is an NSK 885386 water pump bearing. Costs about $15 each. The bearing body is about 2" long and has two shafts sticking out each side that are about 3" long (each). You'll have to cut off most of the shafts and drill a hole thru the shaft for a vacuum passage.
There is NO leakage thru the bearing body on these.
Maybe Al Crandall will respond
Bob Fawcett
>He is the master of these. At one time he had a posting on making an adapter and sold a parts kit with the correct bearings for his method.
Re: Vacuum pump adapter *LINK*
Mkauder, Phenix City, AL Back From Europe
>Here you go Dave.
Made one back when I met Al, and have made a dozen for friends/clubmembers since.
Mark
http://www.woodcentral.com/bparticles/smvachuck.pdf
Re: Been ther, done that...
>I've made several and didn't use any kind of special bearing. All of mine have worked. I have a PDF file on my home computer that describes how to make these. If your interested send me an e-mail and I'll forward it to you.
Dave Shombert
Bill - what about....
Dave Shombert
>I'm close to doing that. The thing that stops me is that I'm used to the 5" diameter handwheel being there, I'm in the habit now of putting my hand up there to stop the rotation. The Oneway adapter is about half the size and I wonder if it would be as effective. A minor point, to be sure. Bill, was this a factor for you?
Dave Shombert
Thanks, Mark, et al!
Dave Shombert
Peter Teubel
>I use a total of 5 regular quick-connect air hose connectors in my vacuum system. No leakage problems at all.
Re: Bill - what about....
Bill Howatt
>I do use the wheel frequently, but not always, in stopping the spindle a bit faster. The vacuum adapter is half the diameter of the wheel but it is smooth apart from a single 3/8 dia hole. You can apply hand friction to the adapter. If you aren't aware, it is about 3.5" long which gives a large area to "rub".
It is very easy to screw on and off so unless you are rapidly going between vacuum/non-vacuum it isn't much of a bother to change. I usually leave it on after doing some vacuum work and then sooner or later I want to knock out a center so it has to be removed; I then put the wheel back on until I need the vacuum again.
The loss of the handwheel wasn't a factor in my decision to buy the Oneway probably because I never thought about it more than clever planning.
Bill
