A real newbie
Terry Alexander
>Ok....so what does the numbers mean when somebody says: #092 vase....or 5236 bowl?
Like I said.....a REAL newbie.
TIA
Terry Alexander
A real newbie
Terry Alexander
TIA
Terry Alexander
Re: A real newbie
>Terry That is probably just the number their camera assigns to the photo. I usually try to rename mine but not always. John
It's also possible it's the..,
Cyril Griesbach
>number assigned by the turner.
Re: A real newbie
Bruce Forrest
>Since you quoted one of my numbers, I assign each finished turning a number at the same time as I sign the piece. I enter the number into a log with some information about the piece into a computer file to keep track of them. The numbering system I use is one I made up which allows me to recognize the year of turning but which will not be totally obvious at first glance.. Others use different systems to code in dates, wood types, types of finish etc. After a while, it can get confusing when you've got fifty ash bowls or 25 poplar hollow forms unless you use some type of numbering.
When I photograph a piece, I label the picture with the identifying number so between the log and the photo, I have a pretty good record of my turnings.
That's my story and I'm sticking to it.
Don't believe what others tell you
Ron in Drums PA
>Don't believe what others tell you about these numbers.
It is a secret code known only to those who post pictures of their turnings here on WC.
So, if you want to find out, let's see some of of your work and we'll tell you how to decipher those numbers.
