OT: ? re breakout replys
ebd
ebd
>I've seen it a number of times and can't see a pattern. Why do some replys to an existing thread suddenly create a new thread (usually with the same subject - but not always)?
Re: OT: ? re breakout replys
Re: OT: ? re breakout replys....reply
Stuart Johnson
>The subject line is changed but it is still a reply.
Charlie Anderson
>I think it has to do with how you set up your preferences. If you only want to see posts from, say, the last week, a reply to a post which is over one week old will look like a new thread.
If you're refering to your reply to 'I give up on Kelton', the reply just before yours was February. Therefore, it looks like a new thread, but depending on how your preferences are set up, when you click on your reply, you may see the original post and the replies which were around that time.
Hope this helps, but I suspect it may be clear as mud.
ebd
ebd
>Actually your response was clear. I guess I never looked at my preferences. Thanks for the info.
