Turning speed for hollowing
Chip in Plano
>What speed do you folks turn when hollowing? I'm working on a wormy piece of mesquite about 5" in diameter. It's still wet some I'm just roughing it out for an DNA bath tomorrow.
Chip in Plano
Re: Chip-I think many turners try ....
Jamie Donaldson
>...hollowing at too high a speed, relative to the tools in use. When speeds are very high, bad things happen too fast as well! And put the tools in and take out of a small opening with the lathe turned OFF- don't ask how I learned that lesson many times over!
Re: Turning speed for hollowing
Wally Dickerman in Arizona
>It's been my observation that most inexperienced turners turn at speeds that are too slow for best results. In my classes at Woodcraft we use Jet mini-lathes. In the beginning hollowform classes we use dry blanks that are 6 in. x 4 in. deep. For those that have little experience I suggest a speed of 1200 RPM. For those with a bit more experience I suggest a speed of 1800 RPM. That's the speed that I would use if I were doing the turning. For larger blanks the speed would be less of course.
Wally
>I turn green blanks slower than dry. I just get tired of getting sprayed. I turn in up until it starts to really spray and then back off a little. You still get wet of course but not as bad. That's probably slower than Wally suggests but I've never been somewho runs a lathe at high speed unless I'm doing spindles.
It depends (Doesn't it always?)
steve antonucci
>I tend to agree with Wally that faster is better (once you get comfortable with the speed...)
I hollow all kinds of wood through smallish holes (0.5-1") and I have typically run the lathe at 700-1000rpm for hollowing. I used to hollow at 400rpm, but it takes forever and the cuts on the inside are not as clean.
Never turn at a speed higher than you are comfortable, no matter what anyone says. If you have wormy, spalted, or otherwise imperfect wood, it's better to err on the side of caution and slow down. I cut a cherry vase with an inclusion yesterday that was 3/16" thick and the inclusion ran the whole length of the vase. Speed helped smooth the cut, but it's a higher risk of catastrphic failure.
Steve
Dick Hines
>Chip as you turn more hollow forms I think your speed will go up. I hollow green wood at a higher speed than I do dry. Dry wood tends to heat up your tools more than green wood does.
I don't know what speed I hollow because my PM 3520 has no speed display. It only reads in freq. and I don't want to ollk the freq. up in the book to change it over to speed.
