recommendation on lathe purchase
linda
>hello,
I have a friend that is interested in purchasing a new lathe. The main uses would be small items (pens and hobby items) but the capability of larger items would be a plus. What would be the recommendations considering a budget of under $1000
thank you
Re: recommendation on lathe purchase
Nova 1624-44 ?
Dave Belser
>I have a Nova DVR, and it has handled anything I've tossed on it with ease. The 1624 is the basically the same lathe with belt driven head. I used one at a demo and it was as nice, smooth and quite as the DVR. The olny mild would be shifting the belt to change speed. The proceedure is easy and quick, but not as fast as pressing buttons or turning a dial. The fact that the head swivels allows you to do large bowls and platters, I've done this a few times.
I'm most likely going to get the 1644 as a second lathe, all of my gear will fit it and I believe it is at the upper limit of portablity. The headstock on the DVR is just to much to lug around.
For big & heavy work you would want to add weight to the stand or build one that you can bolt down. But you shouldn't need to for pens and small stuf.
I make a lot of small stuf (including umbrella tops!) and when I show folks they often say "you must have a tiny lathe to make these!" :) at least I'm not using some real monster!
- Dave
Bob Fawcett
>The advice I got when starting was to purchase a Jet mini lathe. I think it is good advice. It is small and portable, but large enough for many things. The price is around $300. Many in this group started with a mini. Most still have them. They are so useful you don't want to let them go. A bed extension can be added for less than $100 and allows spindles to about 44". The new one has a 12" swing. Once you learn what types of things you want to do, you can get the lathe that suits. You may never want another. There is a model with variable speed for a little more money.
Barry Turner
>My first "real" lathe was a Jet Mini with belt drive. The cost is much less than $1000, but your friend will need more than a lathe to get started, so the extra money will come in handy for a chuck and lathe tools. I wouldn't bother with the variable-speed drive model. I'm not sure it's all that useful in a small lathe. Belt drive is perfectly adequate. It's diffcult to find a drive that is smoother or quieter. I often wished for a larger Jet Mini. I understand there is now a 12" swing model. You can turn an awful lot of stuff and not exceed 12" in diameter.
I now turn on a Stubby 750, but I still have my Jet Mini and have no plans to get rid of it. It's just so nice for wine stoppers, pens, tops, small lidded boxes and such. The Jet Mini may well be the best deal for the money out there.
Ken
>I have only been turning for a little over a yr,but my 1st lathe was and still is a Ricon and I can only say good things about it,but after a little more experience and wanting to turn larger pieces I just got the 1624 the other day and from my few days of using it I have already turnd a 13"bowl with no problem at all,plus I got the Kel McNaughton coring tool and it works fantastic with it.So for a 1000 bucks it's well worth it.Oh there is on thing else he will need and that is a chuck W/insert.I got the nova 2 at woodcraft on sale for 150.00 reg 199.00,you will need the 1 1/4" insert that is 24.00.Good luck.
Ken
wilbur
>To follow up on Barry's point, a lot depends on what your friend already has in terms of turning equipment. If he needs to get turning tools, chucks, and other things, I would say that the real lathe budget is $500, with the other $500 going for turning tools, chucks, and other accessories.
But for $1000, the Nova 1624 is really nice. A friend of mine just got one of these, and he just loves it.
>I've turned on Jet Minis, I like them. From what I've seen the Rikon and the Steel City are getting to be comparable lathes. One lathe worth considering is the General Maxi-lathe (25-200) - it has a price of about $529 on sale. It's about 3/4 hp and has a bed extension available. I've seen them demoed and I've been impressed. It won't turn a big bowl, but it is a nice small lathe.
