Signing your work
Signing your work
Signing your work
Peter Hyde
>I think I am not alone in as much that I have a hard time getting a good looking signature on the bottom of a bowl. Some people can make it a work of art, I can't. I have reduced my signature to a logo but that in itself really doesn't put my name there. I don't like burned or branded signatures and I have been using a Dremel engraver and filling it in with black marker. When it works it's OK, mostly it's a mess. The picture shows an average one. The logo is a compilation of my 3 initials, p,d, and h.
I am thinking about using labels. I figure I can do them on the computer and print them out as needed. They could be glued on with a glue stick and varnished or lacquered over.
Another alternative is a transfer that can be done the same and then warm ironed on to the bowl and then protected with a finish.
Does anyone else use something similar? Any ideas? Any problems with either? What do you think?
Re: Signing your work
Tom Storey
>A common conundrum. We turn beautiful pieces and yet we are unable to put our names on them with any sense of style. Actually, I don't think there is a solution or a problem. Put your mark on it in the best way you can and leave it at that. What we do is not 'production' work so why should our sign-offs be more? Just my take.
Tom
RevDoug
>Do an extensive search on signing work, and you'll find a ton of discussion on the topic. I've recently gotten 2 things that I'm excited about. One is an encraving bit for my dremel tool. Works pretty well. Trick with is it to take your time, go slow. Then again, I think it was Russ who said in a recent similar discussion that we need to slow down anyway. We need to take our time and make it what we can. Good advice regardless of who said it. The second tool I've put into service is an engraver. I think it was something Jenifer said that made me think of it. Anyway, this is going to be my signing tool of choice for a while. Instead of a rotating bit, it has a hard metal bit that vibrates. Again, the trick is to take one's time using it. I'm liking what my results are so far. What you're doing looks good. Practice a lot and make your decision based upon what you find.
Turn 'em round,
keith zimmerman, Normal IL
>I used to sign my work with a sharpie but always disliked the way it looked, and sometimes the ink came off when I buffed the piece.
I have switched to using a dremel engraver to sign my work. With a bit of practice, I was able to figure it out. I'm thinking about putting ink in the engraving so it shows up better, but haven't tried it yet.
keithz
Mike Brazeau
>I have been using a Staedtler .5 mm Indelible Black Drawing & Writing Pen for a couple of years. So far have not had a finish it would not write on and it allows writing even on small items like ornaments. As far as initials etc. I prefer something that tells who I am and will be recognisable (=my name) when I am long gone, especially if it is the family. I also include the year and wood species usually.
Stephen Gehres
>Peter,
I purchased the Razertip Woodburner system from Treeline with the "Extra Small Writing Tip" and the 1.5mm (1/16") Ball Tip. I picked this up after seeing a pen making demo at the Woodworking Show last year. The person giving the demo uses the Extra Small Writing Tip to sign all his work, including pens. He signs his name, the date, and the wood species all hidden UNDER the pen clip. It takes practice, and good 'specs' to sign them this small.
Just my $.02 worth.
~Steve
