REAL MILK PAINT
What finish should I use on
Rich Pearson
>my first small segmented walnut bowl?
I am a new turner (2nd bowl I've done) and not ready for photos yet but I'm working on it!
Re: What finish should I use on
Bob Moffett
Bob Moffett
>I usually use Deft spray on lacquer on segmented pieces. You can get it in spray cans at the big box building supply store. It's easy and fast.
Brian Hahn in SW Wisconsin
>You can use any finish that you want. This may sound flip, but it isn't. I've used Danish oil, lacquer, wipe-on finishes, etc. They all work.
Lately I've been using Waterlox, but that's just because it is what I bought to try out this month.
Greg Haugen
>Second bowl and its segmented?? First question I'd have is if it will be used or for decoration but since this is segmented bowl "utility" isn't too much of an option anymore in my opinion. As the bowl is used the glue will fail eventually. That's also the same reason most "chain store" salad bowls are junk because they're usually staved constructed and will fail at some point. A solid wood salad bowl made and cared for properly should outlast its user. I'd recommend lacquer, spraying it is rather easy and by using steel wool, synth. steel wool, or a very fine grit(1000)of sand paper between coats it's easy to fix any irregularities in the finish. You could also put a sealer on it- any oil finish or most sanding sealers- and simply buff it with wax afterwards.
Hope it helps,
Greg
2nd bowl
Rich Pearson
>Greg, thanks for your help. Yes it is my 2nd bowl.
I've pretty much maxed out our home with flat-side work i.e. gallery grade tables, tansu dressers, office desk, jewelery boxes, etc.
I am learning to turn because it is fun and building the segmented stock is challenging. Aditionally, dimensioned lumber in lots of flavors are readily available in my urban area.
Also, turnings don't take up much space in the home!
Thanks again
Rich
Re: 2nd bowl
Mark Paulley
>Rich,
Once you start turning your home will fill up with bowls, HF and such. You can bet on it!!
Mark
