Variable speed update kit from PSI
John Kyler
>Has anyone ever received one of these kits? Any opinions?
I placed one on order (backorder) and found out that it is delayed again!
Every time I have gone to the web site it keeps showing later dates.
I need to get a small motor with VS for a scroll saw and this was the only KIT I have located (for a lathe or small tool), any options that wont cost a fortune?
TIA
John
Re: Variable speed update kit from PSI
Curly Smith
>My scroll saw has a 90v DC 1/5 hp 1750 RPM (110 inch-oz torque) motor, and presumably VS controller, from RAE Corporation . You might contact them, or one of their dealers, for a price.
You could also spend some time trolling eBay for things like this: 1/4 HP DC motor reversable variable speed which has a current bid of $44 for the used motor (plus another $40 for the controller).
John Kyler
>Thanks for the info.
I know it doesn't need much HP but figured that I could always use the motor on something else if I dump the scroll saw.
I will check them out.
John
eaglesc
>Check the slowest speed on it.
IIRC it was around 700 rpm.
The 500 on my manual jet is still to fast for a slow speed for me.
JERRY COX
>I INSTALLED A PSI VERIABLE SPEED KIT ON MY JET 1014...I AM EXTREMELY HAPPY WITH IT..I USED THE LOWER PULLEY OFF MY JET MOTOR, INSTEAD OF THE PULLEY THAT CAME WITH THE PSI VS KIT...THE LATHE CAN NOW BE SET TO 250 RPM OR LESS; OR IT CAN BE SPED UP TO FASTER THAN IS SAFE TO USE....IT HAS BEEN INSTALLED FOR 2 MONTHS; AND,I USE IT EVERY DAY..
