Wobble in my Chuck
Wobble in my Chuck
Wobble in my Chuck
Philip Duffy
>I have a chuck, a Nova, with big jaws that is used for many big pieces. It has a definite wobble, with or without a bowl attached. Anyone have a suggestion on how to fix this problem? Could it be in the head-bearings of the PM 3520? Does the adapter need to be removed and trued up by itself? I am at a loss and will gladly take suggestions. Phil
Re: Wobble in my Chuck
Bruce Lane
>I had the same problem...I finally figured out that the chuck insert was not seated properly. I removed the insert and reseated...all is well.
good luck.
Bruce
Dito Bruce
Dave Belser
>Check the insert. I have two nova chucks and the inserts can take more effort than you would think to seat properly in the chuck. Once in, I've never had one loosen up.
- Dave
Joe Donohue
>Phil, in addition to making sure the chuck insert is seated properly in the chuck, also make sure the insert registers tight against the spindle shoulder.
It must not lock up on the spindle threads, it must come in contact and register against the shoulder. That's where it gets its proper alignment.
I had a 3520A here. Several face plates and inserts (including a Nova) would not register properly because the spindle nose was longer than standard. I had a 1/8" and a 3/16" spacer made to fit the 1 1/4" shaft to fix the problem. 1 1/4" washers might work as well if you flatten them out.
Joe Donohue
Mike Nelson
>I have a NovaII and when I put the long nose jaws on I notice a definate wobble. The insert doesn't go all the way back on the spindle (3520a) I hope that is my problem will try these steps, thanks.
Philip Duffy
>Thanks to all for the responses. I have done "all of the above" and it still wobbles. So, I put on a 4 jaw machinist chuck and it ran smoothly. So, I guess I need to re-do the adapter and see if it can still be the problem. If that fails then I will swap adapter nuts with a 2nd chuck and see what happens. Phil
Re: I worked on one Sunday. Wasn't impressed.
Al Crandall (N.E. of Indy)
>A club member brought his SuperNova 2 chuck to the meeeting Sunday for inspection. We put it on a General lathe to check it out. The insert seemed to be seated properly in the body and screwed up tight against the lathe spindle shoulder. The chuck body had no runout on the circumference and the face of the body ran true and without wobble. With the jaws not attached, the four slides in the body all met evenly at the center when the scroll was tightened to its maximum. I thoroughly cleaned the slide faces and the back side of the four jaws, and attached the jaws to the body. The jaws had well over 1/16" of runout and wobble when the lathe was turned on. The chuck is less than 1 month old and this is the second set of jaws he has installed because the first set didn't run true. My guess is that Nova has some serious quality control problems. I suggested he try a Vicmarc or Stronghold.
Well, HI There!!, Mr. Crandall
>Nice to see your handle in the pan. You ever gonna post a picture of the walnut?
mm
Wilford Bickel
>I bought a second Supernova off of ebay a while back and when I got it was shocked to find it had run out. Two other Nova chucks I have were flawless. Upon checking insert, chuck body alone and then jaws - I discovered one of the jaws was not right on the bottom. The curved area that seats in the jaw slide was mismilled and had a rounded shoulder instead of being square. I took my dremel tool and squared up the shoulder and that jaw now seats properly and I have a second less than half price Supernova! Check the jaw seating.
Gordon Seto
>I would email or phone Tim Geist, the US service rep for Teknatool. I have several of their chucks, the response and service are top notch.
Phone Tim Geist on
(304) 295-8166 EST
or email to
Tvgeistmfg@aol.com
Gordon
Bill Howatt
>My opinion of the common "good" chucks gained from reading this and other forums is that the Nova series is the more troublesome of the Vicmarc, Oneway, Nova chucks.
FWIW, dissenting opinions welcome,
Bill
Profit sometimes supersedes quality these days.
Gil Jones on Lake Seminole GA
>I have a VicMarc 100 and the Grizzly knockoff of it, plus an old Nova Compac. All of them turn perfectly, with no run-out or wobble.
Re: Profit sometimes supersedes quality these days
Philip Duffy
>After all the input I received I put my wobbler thru a complete cleaning and analysis. I took off the jaws and it wobbled. I removed the adapter nut and mounted it to the lathe. The inner race of the nut was subjected to a fine cutting file to see if there was some off-set. It was then remounted and all the jaws re-attached. Wobbled. When compared to my other Nova, it is a dog. I think it is time to call the Nova tech rep. Thanks to all. Phil
I bet this is obvious but...
Leppikallio
>...does whole chuck wobble or could be just so simple that jaws are not quite properly seated or on right base jaws? Does chuck seat properly to spindle shoulder or could there be some tiny metal chip or bruise in chucks face which seats to spindle shoulder?
Just because wobble which you can see and is obvious is quite big so there should be some obvious reason for it too I think.
Re: I bet this is obvious but...
Philip Duffy
>While your observations are completely proper and understandable, the complete examination of the chuck, jaws, mounting nut and the drive shaft revealed absolutely nothing obvious or out of place. The wobble is obvious and apparent when standing at the normal position and I can see the exterior of the chuck move appreciably. When I use a fixed-point measurement of the plane of rotation the offset is about 1/32 of an inch. That seems small until you watch it turn and you are trying to accomplish some delicate piece of work, then it looks huge. I have to wonder if the threads of the body or the threads of the adapter nut are mis-cut. I have an identical chuck and it runs as smooth as glass. I would swap the nuts of these two chucks to see what happens but am afraid to ruin the one good one by changing something! Phil
Call the rep!
Wilford Bickel
>I agree Phil - with what you have checked it is time to let Nova/Teknatool help. They give great service and I am sure will have this straightened out in no time.
RevDoug
>If the other identical chuck runs smooth, swap out the insert and see if the chuck in question runs true or not. If it does you need a new insert. If not, there's a problem in the chuck. That's when you need to drop a dime to Nova.
Turn 'em round,
Defective Threaded Insert ? ? ?
Barry Turner
>I bought a new Super Nova II chuck that also had a wobble. When I switched inserts with the one in my older Super Nova chuck........no more wobble. I emailed Teknatool and they shipped me a new threaded insert at no charge. Problem solved.
Barry
Re: Defective Threaded Insert ? ? ?
Philip F Duffy
>Thanks, Barry, I am about to do the same thing and will report results. Tech rep wants me to ship the chuck but I think the insert switch is the first order of business. Phil
