Sooooooooo..Ruth
Sooooooooo..Ruth
Sooooooooo..Ruth
Mac
>How's it going with the lathe? Find the problem yet?
Re: Sooooooooo..Ruth
Ruth Niles
>I did do that small job on the General and he didn't complain; he's such a trooper!
I did everything everyone suggested (well almost!) and can't find any loose set screws, nothing (I can see) rubbing, so it must be the bearings. I really don't want to take the headstock all apart and try to find new ones and what do I get the bearings off with? my pipe wrench is bent. I sure did learn a lesson, for this month at least.
I'm wondering ......
>exactly what went wrong? I read the whole saga about the stuck face plate and made a few suggestions. I would have been reluctant to go thermal on my lathe, but I would have applied a lot more hammering and no doubt a few more choice words.
Wonder if you could replace the grease in the bearings without taking them out? I'm assuming here that heating them melted or drove off the grease. Probably won't work, but why not shoot them with some penetrating oil and see if it helps? I'd blow them out with compressed air if I could and then soak them with some sort of oil and maybe run the lathe slowly while I was at it. This is the take a whack at it approach and completley unscientific. The gresse got out (maybe?) so maybe it can get back in. The good news is that it probably falls in the "couldn't hurt" part of the tool repair spectrum. It's based on the concept that you can't break something that is already broken. Exactly the same reason I am going to take a whack at squaring my unsqaure framing square. (litteraly)
Might be a little messy, but other that I think there is no harm. At least quiet the General down until you get new bearings.
squaring a framing square.....
TDaniel
>Barry, if your square is less than 90 degrees try a few light taps to the inside corner with the ball end of a ball-peen hammer.
Failed bearings
jdillbeck
>Ruth I have followed your face plate problem and now your vibration problems.One of the areas of concern when you hammer or apply large loads to a bearing, as in trying to remove a stuck faceplate is damaging the bearings.Try to picture the bearing, A ball between two races and you are applying a shock load on the inner race by hammering on the spindle. What happens is you can brinell i.e. dent the the races, resulting in a rough running or high friction bearing that will eventually fail. Most of the time you can feel this by hand. Remove the drive belts and slowly rotate the spindle. If you come to a high point slowly move back and forth and it will feel like a detent in the bearing. Good luck
You need a bearing puller *LINK*
wilbur
>The best tool for removing a bearing is a bearing puller. I've attached a picture of what one looks like. The jaws clamp behind the bearing and the tip of the screw rests against the end of the shaft. As you turn the screw, the bearing comes off.
I have jury rigged some wood and clamps to do the same thing in the past, but using this tool is much easier.
Sears has them for about $50. I'm sure there are other sources as well.
A local auto repair shop might be able to pull the bearing off for you for a nominal cost, if you bring the shaft to them
Regreasing the bearings might be difficult if you have sealed bearings. You run the risk of not getting enough grease in past the seals, or ruining the seals by being too exuberant with pushing the grease in. I've rehabbed open bearings by soaking them in naphtha and repacking them with grease, but I've never tried this with a sealed bearing. It's far easier just to replace them.
Be careful putting the bearings back on. You'll want to press them on, not bang them on with a hammer. There is a tool called a bearing press, but I recently posted in the main Woodcentral forum a couple of ways to get a bearing back onto a shaft without special equipment, linked below.
Finally, it's easier than you think to deal with bearings and such. Good luck!
How to get bearings back onto a shaft
Chuck Engstrom
>Hi Ruth -- a good electric motor repair shop can probably help you with getting bearings on and off, and be able to supply them as well.
Best--
Chuck
Re: You need a bearing puller
>Ebay has them as a set of 3 for about $20
>Excellent suggestion Chuck. I had that done on my first lathe. I was looking for someone to help get the shaft out of the headstock on my first lathe and happened upon the local motor repair place. They pulled it out and put new bearings on for a very small charge.
Re: squaring a framing square.....
Gary Evans Tallassee, TN
>A center punch on the inside corner also works well and lets you "sneak up" on the re-calibration.
Gary
RUTH, YOU PROMISED I'D BE THE FIRST TO KNOW---
Ken Oakley-Sunny St. Cloud, Fla.
>They also need recalibration. I checked mine the other day and it had gotten off somewhere along the line. I thought I was pretty careful with that thing. Re-peened it and got it back on.
Nothing NEW happened when I used the lathe!
Ruth Niles
Bob Fawcett
>Ruth,
Get a small stick of wood, put one end on the headstock and the other next to your ear. You can hear the noise while it is running. Once you have the idea, move your "listening stick" around to other parts of the lathe. You should be able to tell where the noise is coming from by the relative volume.
When you locate the source, you will know the reason you have noise. If it is the bearings, you can probably get a local machine shop, or motor shop to help you replace them, if you don't want to tackle it yourself.
Wayne Allen, Carson City, NV
>Ruth -- Like I mentioned earlier, This is really not a big deal. The shaft is easily removed from the lathe. Take the shaft (with bearings attached) to a bearing supply shop and buy 2 new bearings (probably less than $10.00). Then ifthe bearing supply can not remove and install them, take them to a machine shop and they will do it for a nominal charge. Putting them back is the reverse of taking them out.
