Dri-Cote might help
Curly Smith
> Dri-Cote
"Dri-Cote is formulated for use on high-speed cutting tools such as shaper cutters, saw-blades & router bits. By locking a low-friction, high-temperature resistant coating into the surface of carbide or steel cutting tools, Dri-Cote significantly slows accumulation of baked-on resins & crud that increase friction, inhibit chip clearance, and generally make edges act dull. Used regularly, Dri-Cote reduces chemical corrosion of carbide tooling, and can noticeably extend edge life when cutting synthetic materials such as Corian or sheet meterials with abrasive adhesives."
