Dye- Fade Proof?
nailshooter
>George - I do a lot of finishing as a repair and remodel contractor. For cabinets and stained/dyed woodwork, I only use dye when I can get away with it. I have found it to be quick, easy to apply, and with a little fine tuning you can turn out some beautiful, natural looking finishes. I started using dye to speed up the wood coloration processes in the field.
After a lot of testing, including testing for color fast ability in a high UV environment, I only use Behlen's Solar Lux. It is alcohol based so it dries rapidly, and it shoots well with a gun. To get more natural colors with the product, I only shoot it on, I don't wipe. YMMV.
I looked and and tried other products, but the only other close contender was J. Jewitt's Trans Tint product. But I was warned off of this on a finishing forum as one of the guys there had problems with fading on a table top that was sitting in a window are that got a lot of sun. In about three years most of the top was a different color than than the legs and sides.
I pointed out to him that there is a disclaimer on the bottle that says it isn't UV/light resistant.
I put Behlens SL on exterior doors, cabinets, etc., and have never had a problem. It seems like $12 for a pint is a little expensive, but I cut it by 2/3 to 1/2 with anhydrous alcohol to shoot it out of a fine nozzle or air cap. Never had a problem.
Robert
